Franken-Tractor Is Here To Screw Everything
Every single one of you thinks you have the ultimate off-road vehicle. You think you could conquer anything and everything you see before you. You believe that because you have a winch, 33” tires, and a dope suspension setup, that you are the king of the mountain and of everything you see before you. We’re here to tell you, you’re hopelessly wrong.
This is the ultimate off-road vehicle, and it’s not even a Jeep. What you see before you is a tractor, but no ordinary tractor; it’s a tractor with a screw-drive. Essentially, a screw-drive is where you have a system that propels you forward by pushing dirt or other matter away from you with an impeller shaped like a screw. Actually, it’s rather hard to put into words, but it makes perfect sense after you see what we’re talking about in the video below.
What’s interesting and slightly cool about this one, and no it’s not the Canadian flag hanging off it, is the Jeep-esque front the builder installed on this Franken-machine. Check it out, but careful, there’s a little NSFW language after the driver ends up getting it stuck in the mud. Okay, so maybe it’s not the ultimate off-roader after all.
Chime in with your thoughts on the forum. >>
Via [REDNIC79]
