KC HiLiTES Updates its C Series LED Lights
KC HiLiTES, the pioneer of off-road lighting, has updated its C Series LED Light Bars and has added U-brackets for the C Series LED Light Bars. The updates have increased the power output for a brighter light output. The end caps of the C Series LED Light Bars have been redesigned and the mounts are now serviceable to make maintenance and repairs easier. All sizes of the C Series LED Light Bar also feature GORE Breathers, a vent designed by the same people who created GORE-Tex. It provides a rapid pressure equalization and release to extend seal life and minimizes condensation through better vapor diffusion while keeping contaminants out.
Each LED is rated to three watts, and total wattage ranges from 60w to 300w depending on length. Output ranges from 4,200 lumens to 21,000 lumens on the 50-inch-width model. Each bar features a 12-degree spot and 30-degree spread pattern, making the C Series a combo beam in a color temperature of 6000K, with a 50,000-hour life expectancy. You can get the C Series light bar in 10-, 20-, 30-, 40-, and 50-inch widths.
KC HiLiTES also introduces the new U-Brackets, a universal mounting bracket for the C Series LED Light Bars for flexible mounting options. If you already have KC Front End Light Bars on your truck or JK, you can mount these in the same place on two- and four-tab light mounts. The C Series U-Brackets include all of the hardware needed for mounting.
