Pinewood Derby Jeep
Pinewood Derby Jeep
Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    JK Junkie scouter4life's Avatar
    Join Date
    Aug 2007
    Location
    Gilbert, AZ
    Posts
    2,944
    Default Pinewood Derby Jeep
    Has anyone built and/or have pictures of a Pinewood Derby car that looks like a Jeep? My boys have one coming up and wanted to make Jeeps, but I'm not good at coming up with the design, i need something to start with.
    '08 Sahara Unlmtd 4X4, Jeep Green, khaki, MyGIG Lock pic'd, Rear & front cameras, 6spd, 2.5" TF BB, Jeeperman Rear with carrier, 32" BFG KM's, WP Rack System, Ultimate Air CO2, all sorts of lights, Cobra 75 CB & Yaesu 2600M Ham, Smittybuilt XRC-10 Winch, Olympic sliders, 4x Fix-it front bumper, AEV Snorkel
  2. #2
    JK Enthusiast VOLJEEPX's Avatar
    Join Date
    Aug 2007
    Location
    Kentucky
    Posts
    242
    They'll be as aerodynamic as a brick, though!
    2010 RED ROCK CRYSTAL SPORT 2 DOOR
    GO VOLS!!!
  3. #3
    JK Junkie CLACKEY(_!_)'s Avatar
    Join Date
    Dec 2006
    Location
    Highland, Utah
    Posts
    3,129
    Brick shapes are good in pinewood derby's
    *_________ *
    ____________________________________________
    35x12.5x18 Nitto Mud Grapplers on stock Sahara wheels. 3" Full Traction Ultimate HD & 3/4" coil spacers front & rear
    PureJeep front stubby with winch plate, PureJeep rear w/carrier (_!_) 8" KC"s on Mopar pillar mount brackets, WARN POWERPLANT
    CLACKEY FLAT FENDERS, Woods ss relocation, Woods evap relocaton, Fab Fours Rock Sliders
    KEEP WAVING. EVENTUALLY THEY'LL WAVE BACK
    YOU TUBE VIDEOS
  4. #4
    JK Freak YellowToy's Avatar
    Join Date
    Apr 2008
    Location
    Mt. Pleasant, SC
    Posts
    888
    I just started this last night & will post a full write-up when done (hopefully this weekend).
    Obviously I'm going with a 4DR JK with Yellow paint.
    By the way, this is for the "Family & Siblings" entry. My 8-yr-old is cutting his own car with the dremmel & I'll install the weights for him once he's finished.
    2012 Unlimited Sport - [B]
    mods:
    - MBRP ROOF RACK INSTALLED
  5. #5
    Join Date
    Apr 2008
    Location
    Mt. Pleasant, SC
    Posts
    888
    Quote Originally Posted by putnam dan View Post
    the trick is to ensure that only two / three wheels actually touch the track this reduces rolling resistance and provides a winner
    We tried that last year. Built a three-wheeler and named it "Tri-Anything." The balance didn't work out, & it had a "death wobble" in the straight-away.
    This one is going for most original design. The aerodynamics aren't important at these speeds, but I had to shorten the wheel base to get the proportions correct, so it probably won't be too fast.
    mods:
  6. #6
    JK Super Freak NE Wrangling's Avatar
    Join Date
    Nov 2007
    Location
    Massachusett
    Posts
    1,258
    The real trick to the races. Astroglyde on the wheels makes them run real smooth, forget the graphite pen.
    Also try to sand a little off the bottom of the vehicle. Beleive it or not the derby car's do touch the track so when you put the weights on the car put them front to back. Use lead tape strips or copper wire strips of 10 GA. front to back imbedded if you pan to put underneath.
    When I did it as a kid, having the weight as headlights/taillights seemed to dispurse the weight better. I came in second to Engineer dad kid.
  7. #7
    JK Super Freak sixt7gt350's Avatar
    Join Date
    Oct 2007
    Location
    The Badlands (near Lafayette, IN)
    Posts
    1,592
    Just don't use the white lube crap that some districts restrict you to.
    My daughter's first year in the GS Powder Puff derby didn't restrict lubes. The next year, they did. That white crap was worse than no lube at all.
    Wheels (axle polish, wheel gate smoothing, alignment, etc.) and weight distribution are key.
    Aero makes a small difference at the size and speed, but a cool looking derby car is much more appreciated than one that was made just for speed.
    If you like our Jeeps, you ought to see our lakes!
  8. #8
    JK Enthusiast Mowabb's Avatar
    Join Date
    Sep 2007
    Location
    NSL, UT
    Posts
    384
    We used tips and products from both of these guys to build my son and daughters cars:
    http://w w w.maximum-velocity.com/
    http://w w w.derbychamp.com/
    A few of the tips I used were:
    • Notch the axles and angle the head to reduce the contact point with the wheel.
    • Most of the weight in the back, but make sure you balance the car as to not pop wheelies!
    • Either V-shape or groove the wheels to reduce contact with the track.
    • As mentioned, three wheels making contact = less friction.
    • V shape notch in the front of the car w/ a U shaped hoop above-made with a paperclip, to get a slight head-start when the starting pin drops.
    I am sure I am forgetting a couple but we have built three cars and have not lost a race-except against our cars!
    Good luck!
    P.S. Big brother was really mad when his little sisters car beat his...
    08 Unlimited Rubicon
  9. #9
    Join Date
    Nov 2007
    Location
    Massachusett
    Posts
    1,258
    man that design looks familiar... That was like the one I had but mine was green for the green hornet... I forgot about angling the tires a little. My first car ever I built myself and it was nearly the block they gave me and I came in 3rd. the next two years I built a rocket shape then a VW bug style. This design was definately best for winning. Engineering dad's kid built it full width but as thin as yours with oval cutouts front to back. I loved the derby races.
    with a dremel I can easily see reducing the tire contact. We didn't have that back in my day.
  10. #10
    Join Date
    Oct 2007
    Location
    Posts
    1,592
    Quote Originally Posted by Mowabb View Post
    Good luck!
    Strict rules prohibit shaping the wheels in many districts.
    This was a rule in my son's pack, but the cars were never inspected prior to the race.
    The scout that won had rounded his wheels to the point that none of the sidewall lettering/design was present. The parents agreed that the 2nd place should have won, since he followed all the rules and barely lost.
    The other suggestions, I agree with, however.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
