Canoe on soft top - Page 2
Canoe on soft top
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    JK Enthusiast dustdriver's Avatar
    Join Date
    Feb 2009
    Location
    NE Oregon (the dry side)
    Posts
    219
    Quote Originally Posted by TxCop07 View Post
    Can you take the front bracket off easily? When not carrying the canoe.
    Sorry, missed that! YES very simple to remove. Two bolts, one on either side where the vertical tubing inserts at the windshield bracket- the originals are knobs but I replaced them with standard bolts because the knobs had a tendency to come loose on long, bumpy drives and couldn't be tightened sufficiently by hand.
    I am planning to replace the horizontal front bar (which is a wierd oval shape, compatible with other Lange accessories) with 1" round EMT conduit so I can fit my Yakima gunwale brackets on there. I will have the new bar welded on so there will be no chance of any bolts working loose.
    Amazingly, NOBODY (that I can find) makes such a product already... so I have to Frankenstein it myself. :/
    2014 Unlimited Rubicon
    "Just because you can do something, doesn't mean it's a good idea."
  2. #12
    JK Super Freak TxCop07's Avatar
    Join Date
    Jan 2008
    Location
    Somewhere Down in Texas
    Posts
    992
    Ok that's cool. Keep us updated as you upgrade it.
    2007 JEEP Green Rubi
    4" Complete RC lift
    2" Performance Accessories BL from Northridge 4x4
    37" Goodyear MTR's
    OLYMPIC 4X4 front bumper
    8K winch
    48" HighLift Jack
    Cobra CB
    Camo grab handles
    _________
    |__\__\__|
    == llllllll ==
    | | * o..o * | |
    | | ---O--- | |
  3. #13
    Join Date
    Feb 2009
    Location
    Posts
    219
    OK here's the final version. This system will work with:
    1. hard top
    2. soft top
    3. no top
    It's easily removable, very sturdy, and I can still carry 2 bikes on the back, and the 1" conduit is compatible with other rack accessories (i.e., Yakima, etc.)
    Front:
    Windshield brackets and verticals from Lange. 1" EMT conduit across the top.
    Back:
    Mopar spare tire bike rack with welded "T-bar" for the back of the canoe.
  4. #14
    JK Enthusiast akoop's Avatar
    Join Date
    Jul 2010
    Location
    Northern, NJ
    Posts
    181
    Here is my write-up on hauling a canoe & kayak on a soft top.
    http://www.jk-forum.com/showthread.p...noe-Kayak-Rack
  5. #15
    JK Enthusiast schmugboy's Avatar
    Join Date
    Feb 2009
    Location
    ABQ, NM
    Posts
    134
    Default Another option
    Another idea option, if you wanted to have the soft top up, would be getting some of that pipe insulation and put it over the lip/sides of the canoe. That should provide enough cushion on the top and it should wear away faster than the top if anything gets between them. Haven't tried it myself, but thought about it.
  6. #16
    JK Jedi AK4Dave's Avatar
    Join Date
    Aug 2007
    Location
    Kenai Peninsula, Alaska
    Posts
    5,813
    Quote Originally Posted by schmugboy View Post
    I would be leery of putting anything directly on the soft top for any long distance trip. But for a short trip down the road I do believe the pipe insulation would work fine. Just as long as you can keep the canoe from shifting even just a little from side to side.
    07' Silver X 2dr Softop (dd)
    16x8" 4.5" bs Eagle Alloys 140 / Super Fin/Blk trim
    33" Bridgestone "Revo" Dueler AT
    Stock Sahara Running boards
    I installed OEM cruise/speed control
    Airaid CAI
    Superchips Flashpaq
    Light Force 240 "Blitz" Aux lights
    Waiting to install "WARN CE M8000" winch
    Can't decide on....
    Bumper and Lift.
    http://my.project-jk.com/showgallery...00&ppuser=1848
    www.northridge4x4.com
  7. #17
    JK Newbie bripsu's Avatar
    Join Date
    Jun 2010
    Location
    State College, PA
    Posts
    99
    Quote Originally Posted by dustdriver View Post
    Very nice. Looks very similar to the Lange Originals Rack, but I'm sure you spent less.
  8. #18
    Join Date
    Feb 2009
    Location
    Posts
    219
    Quote Originally Posted by bripsu View Post
    Thanks. Yeah the lower front sections are from Lange, but I replaced the original oval-shaped bar across the top with the round pipe. If Lange were smart, they'd do the same, to make the rack compatible with a thousand other Yakima and Thule accessories. And someone needs to make a spare-tire mounted upright for the back. They'd sell a ton of them.
  9. #19
    JK Newbie JKFORLOVERS's Avatar
    Join Date
    Jun 2009
    Location
    Bowling Green Ky
    Posts
    31
    http://hphotos-sea1.fbcdn.net/hphoto..._1175272_o.jpg
    I sliced some 99 cent noodles and ran along the canoe so it didn't wear out the top anymore than I already have. You will need padding or it will die! Works great though. No rack need!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    4wd.com
    Northridge4x4
  10. #20
    JK Enthusiast ravenswood's Avatar
    Join Date
    Nov 2011
    Location
    Barrie, Ontario
    Posts
    188
    I just picked up a Garvin Adventure Rack for our canoe. It is a full body rack, connects to the windsheild bolts and under the rear bumper. It tilts back to drop the soft top. Looking forward to the spring when I can start using it!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
