Esc light
Esc light
When I am driving and I hit a bump/dip in the road (not necessarily a pot hole), my jeep rocks back and forth and my esc light flashes on and then makes my jeep brake for second. I know what a death wobble feels like and it isn't that. I have no idea what this could be. Thoughts?
Sounds like something with the traction control on your JK.
Probably a wire that is rubbing against something sharp when you hit the bumps and is shorting out.
My TJ does not have that newfangled and don't have to worry about it.
Not sure what the esc light represents though.
Might try pulling the fuse for that system to see what happens.
If still under warranty, might take it in also.
Todd
Todd
Recommend you take a look at this for good measure - https://www.jk-forum.com/forums/jk-w...obbles-260145/
I have replaced track bar, drag link, and tie rod. All synergy products. My bushings on the stock track bar we're going bad and I started the death wobble. Now I don't have the same wobbly feelings, other than what I described.
