Minnesota's ramble on and on thread.
#8621
With all the dust from the trails and the hot Temperatures during the day and then the heat from the engine, not really a good place for them down here. Everything has it's pro's and con's. It did take a bit more wire to do it and to mount it right just time consuming.
The LED Bar is just right for the roads down here, where distance does not matter.
#8622
JK Forum Regional Rep
#8623
I know a guy selling front and rear rubicon axles with 13k miles on them. I only need the front. Would anyone be interested in a rear factory rear rubicon axle with a locker and 4.10 gears for $2k?
I would handle transportation for the axle to your door and could help with the install if you want.
#8624
#8625
I'm looking at my options right now. I knew the D30 would not live under my JK for ever with the tire size I'm planning. The upgrades will make it a decent upgrade for someone when it's time.
#8626
#8627
Synergy ball joints, EVO sleeves, EVO C2 gussets (upper and lower), EVO lower control arm skids. The knuckles have been drilled (with a tapered bit) to accept a drag link flip (currently running the synergy drag link).
I also have 4.10 and 5.13 gears for it.
Right now the spider gears need to be replaced along with the bearings for piece of mind.
#8628
Thinking of having a meet and greet Saturday August 23rd and if anyone is interested the local dealership is having their 1st off-roaders meet and greet on Saturday September 6th from 9:00 AM to 1:00 PM
#8629
I was planning on being gone but with the recent axle issue I may be stuck here. I'll put it on the calendar if I can get down there. It's been too long.
#8630
