2008 JK 2dr Built 65,000mi $25,000
Whether your mall crawling or rock crawling this Jeep is build for both worlds. The 4" Synergy springs and Fox shocks provide plenty of clearance for the big beefy 37' Nitto Trail Grapplers. A fully adjustable heavy duty suspension with raised drag ling and flip kit gives you a nice smooth ride. The Dynatrac PR44 Front axle eliminates the worry about broken and bent axle housings, improper caster and driveline angles. A Chromalloy axle, ARB lockers and 5:13 gears offer added strength and torque to keep the tires turning through some of the most difficult trails. Poison Spyder sport cage to keep you safe and Mastercraft seat belts to keep your butt in the seat. Have a friend in need pull them out of trouble with the 8K winch.
Tires, shocks & springs recently replaced only around 10K mi. on them.
Clean Title in Hand
Will Post Pics ASAP
Build Sheet:
Year: 2008
Model: X
Color: Black
Transmission: Automatic
Suspension:
Synergy 4" with Fox Performance Series 2.0
Currie Adjustable Control Arms
Currie Front Antirock
Synergy Front Track Bar
JKS Rear Track Bar
Synergy Tie Rod
Synergy Drag Link and Flip Kit
Drivetrain:
Dynatrac PR44 Front
Nirto Chromoly Rear Axle Shafts
ARB Airlocker F&R
J.E. Reel Rear DS
Custom Front DS
5.13 Gears
Wheels & Tires:
Nitto Trail Grapplers 37x12.50x17
Mickey Thompson Sidebiter 17X9
Bumpers:
Front-Rugged Ridge XHD Stubby
Rear-Warn RC w/ Tire Carrier
Armor:
Rock Hard 4X4 Rock Sliders
Poison Spyder Trail Cage
Rock Hard 4x4 Evap Relocation Bracket
Winch:
Smittybilt XRC-8
Performance:
Superchip Flashpaq
K&N Air Filter
Lights:
KC HiLites
Clean Title in Hand
Will Post Pics ASAP
Build Sheet:
Year: 2008
Model: X
Color: Black
Suspension:
JKS Rear Track Bar
Synergy Tie Rod
Drivetrain:
Dynatrac PR44 Front
ARB Airlocker F&R
J.E. Reel Rear DS
Custom Front DS
5.13 Gears
Wheels & Tires:
Bumpers:
Armor:
Winch:
Smittybilt XRC-8
Performance:
Superchip Flashpaq
K&N Air Filter
Lights:
KC HiLites
This is a well taken care of Jeep. Fluids were changed with Mobile 1 on a regular basis and thoroughly cleaned after trips. The suspension is all dialed in for full articulation with proper bump stops and brake lines. The control arm JohnnyJoint are also recently rebuilt.
I'm open to cash offers so don't be shy.
Thanks,
Thanks,
