Archived - Jeep XJ Cherokee & Grand Cherokees Discuss the Jeep XJ Cherokee and Grand Cherokee at our sister community. This includes all Jeep XJ's made between 1984-2001 and all Grand Cherokees made to this date.
98 xj doesn't crank over first shot.
Old 02-28-2012, 04:39 PM
tattedJkers's Avatar
Default 98 xj doesn't crank over first shot.
My 98 cherokee doesn't crank over first try, sometimes it takes up to 5-6 trys. Replaced the battery and cleaned the terminal cords last night. Was wondering if anyone else had this problem at all.
tattedJkers is offline
Old 02-29-2012, 09:32 AM
Johnjk's Avatar
When it doesnt start do you got à puls on your starter engine. If you dont have à puls try to swap your relay with your Horn relay THE problem could also be your electrick ignition lock
Johnjk is offline
Old 02-29-2012, 12:48 PM
I'm not sure what you mean by pulse. Someone said maybe a fu pump issue. And how do I know if its my ignition lock?
Old 03-01-2012, 06:25 AM
Johnjk's Avatar
Is your engine cranking and doesnt fire up or no crank at all
Johnjk is offline
Old 03-01-2012, 06:32 AM
Johnjk's Avatar
There might be some mistakes in my writethings iam from THE netherlands
Johnjk is offline
Old 03-01-2012, 12:04 PM
It's cranking, it takes a little bit before it actually starts.
Old 03-02-2012, 10:54 AM
ZMagic97's Avatar
A little bit such as 5 seconds? Mine has done the same for 60,000 miles or so. Someone once told me it was the crank sensor and that it can take an entire revolution or so of the crank for the computer to realize where the crank is prior to firing. Not sure if that is true, but makes sense to me. Also, it could be a fuel pressure issue (maybe just a filter?) I wouldn't be too concerned right now if i were you, I have been driving mine like this since i owned it and my friends ZJ is the same way.
ZMagic97 is offline
Old 03-02-2012, 11:13 AM
Running Man's Avatar
Start with checking the fuel filter. Try removing it and blowing through it. If it is hard to blow through, I've seen this cause issues with starting. Next, progress to checking the ignition system (e.g. plugs, wires, cap, etc.). The problem is likely in there somewhere!
Running Man is offline
Old 03-02-2012, 02:25 PM
Thanks for the info. Do you by chance know where the fuel filter is?
Old 04-19-2012, 12:27 AM
grumpy1's Avatar
yeah its back by the rear drivers side tire mounted on the frame. Its about 5 inches long and about 2 inches in diamiter. Just so you know make sure you release the pressure on the fuel line, there's a valve on the fuel rail where the injectors are located on the engine its just like a tire valve.
grumpy1 is offline
Quick Reply: 98 xj doesn't crank over first shot.
