Lightly Used...Killer Set-Up 2008 Jayco Baja 10Y with all The Fix'ins!!
" SOLD" Lightly Used...Killer Set-Up 2008 Jayco Baja 10Y with all The Fix'ins!!
Ok,
So We're selling our Jayco Baja 10Y $9500.00 OBO.....Very sweet Set-up!! It was Ordered with Every Option Available Furnace, AC, Shower/Tub/Toilet, Stereo and More Which I'll list...Plus
These items we've changed..
Thanks for looking
Gregory
- (2) Burner Stove/Oven Added
- (3) way Popane Gas Adapter on the Out Side...To Run BBQ, Potable Cook Top, and (2) Burner Stove/Oven at one time If you Choose to!
- (1) Large Diamond Plate Job Box Added to Front Storage Area
- (2) Diamond Plate storage Boxes added to Rear Bumper
- Awening Modified to attach to Trailer Frame
- Oak Hard Wood Table with Drop Leaf Fabriacted.... Replacing Press Board Factory
- Water Proof and Collapsible Roof Mount Interior storage Units Added
- Removable Weather Proof Railing Added to Rear Bed Over Hang....USed for Shoe Rack, Dry Clothes, Towels...Whatever you like!!
- Removable Kitchen Organizer Fabricated....Made to Pogo by the Kitchen Sink!
As Ordered Infomation:
Standard Heat, Power and Water
Double 20-lb. propane gas bottles, with vinyl cover
Hookup for city water
12V electrical system with 20-amp. 110V converter
17 gal fresh water system with 12V demand pump
30ft 30 amp power cord
Porta-potti storage cabinet (N/A 806, 1207)
Water heater bypass system
Standard Exterior Equipment
14" x 14" roof vent
15" off-road Dunlopฎ Mud Rover radial tires
Cast aluminum 110V G.F.C.I. protected exterior receptacle
DURATEK water-repellent sectionalized tent
Crank-down stabilizer jacks with sand pads
Diamond-plate walls on front and rear
Domed, fiberglass roof with no center seam
Double entrance step
E-Coat protected frame
Electric brakes
Entrance door access with roof lowered
Entrance door is 1-piece construction
Extrusions for box top are painted (powder-coated) black with black corner caps
E-Z Lubeฎ axles
Floor is undercoated and constructed of edge-sealed Structurwood
Front storage deck with expanded steel surface and aluminum deck railing
Jayco's original, fully enclosed lifter system (same design used since 1968)
Leveling jacks and heavy-duty A-frame construction
Lifter post covers integrated into tent
Mud flaps
One-piece high-density polyethylene wheel wells
Patio light with amber lens
Prep wiring for battery
Rear bumper made of 4" tubular steel
Rubber truck-type fenders
Scratch resistant, embossed aluminum finish on exterior
Shock absorbers (racing yellow)
Spare tire and tire carrier
Entrance door caddy
Tent attachment velcros around entrance door
Vinyl spare tire cover
Wide-body construction
15" black steel rims
Double aluminum exterior sidewalls
Exterior entrance door storage with securement strap
Moto graphics
Ramps / deck railing (dual use) with quick-connect deck attachment system
Rounded wheel wells
Self-storing screen door
Bed bases are undercoated
D-rings (6) welded to front storage deck
Standard Kitchen Equipment
Appliances are pre-plumbed for propane gas
Carry-out dinette table
Stainless steel sink and faucet
Stainless steel carryout stove (2-burner)
6-gal. water heater (N/A 806)
Standard Interior Equipment
12V high-intensity lighting
Automatic cut-off switch for interior lights
Bed flaps that cover edge of bed
Powder-coated white bunk end bows with adjustable tension tent supports
Tinted vinyl windows
C-clamp connection on tent supports
Door pulls with roller catch
Drawers are made of real wood and have nylon guides
Bunk-end fan lights (1 or 2)
Manchester Oak hardwood flat panel cabinetry
Coordinated furniture, designed and made by Jaycoฎ
Hinged dinette seat bases
Mildew-resistant aluminum ceiling
Non-sliding, 4" deep cushions for dinette with reversible EZ-clean vinyl backs
Prep for A/C accommodating all roof-mounted A/C's
Privacy curtains for end-bunks
SoftShade window shades and valances
Vinyl flooring wall to wall
110V G.F.C.I. protected interior receptacle
Booth dinette
Granite-look countertop
Table extension
Modern interior designed and made by Jaycoฎ
Brushed nickel hardware
Cup holders installed throughout
Heavy-duty entrance door securement latches
Standard Safety Equipment
Break-away switch
Dual hitch safety chains
Fire extinguisher
Propane alarm
Carbon monoxide alarm
1200 lb. front deck capacity
Customer Value Package
2-cu.ft. 3-way gas/electric refrigerator (110V/12V/Propane)
AM/FM stereo and CD player
Battery gauge
Prep for solar power
Self-storing awning made by Jaycoฎ
Water purification system
iPodฎ Adapter
Options
Portable, outside gas grill
16,000-BTU furnace with auto-ignition
13,500-BTU Roof Mount AC
Deluxe screen room
2-cu.ft. 3-way gas/electric refrigerator (110V/12V/Propane); AM/FM stereo with CD and iPod adapter; Battery gauge; Prep for solar power; Self-storing awning made by Jaycoฎ; water purification system
Bath/shower option
CSA Standards
Thanks for looking
Gregory
14" x 14" roof vent
Electric brakes
E-Z Lubeฎ axles
Mud flaps
Entrance door caddy
Moto graphics
Rounded wheel wells
Booth dinette
Table extension
Break-away switch
Fire extinguisher
Propane alarm
Battery gauge
iPodฎ Adapter
Options
Deluxe screen room
Bath/shower option
CSA Standards
