Alright CB geniuses, get in here please!
Like everyone else has said the internal SWR meters are sketchy. Those tailgate antenna mounts can be a little difficult to deal with too. The tailgate is poorly grounded (bonded) due to the hinges.
What's your location? Maybe we can get some local help or direct you to a decent shop.
Like everyone else has said the internal SWR meters are sketchy. Those tailgate antenna mounts can be a little difficult to deal with too. The tailgate is poorly grounded (bonded) due to the hinges. What's your location? Maybe we can get some local help or direct you to a decent shop.
Do you think I damaged anything with the insulator under the mount?
Yes you can but need to use a fairly heavy braided ground strap. Before going that route I would verify with an external SWR meter.
Unless you transmitted for a long time I highly doubt anything burnt up inside the radio.
Are there any local truck stops in your area? If so they typically sell SWR meters. Also some Radio Shack stores still stock SWR meters. You will also need a short piece of coax cable to use as a jumper.
Yes you can but need to use a fairly heavy braided ground strap. Before going that route I would verify with an external SWR meter. Unless you transmitted for a long time I highly doubt anything burnt up inside the radio. Are there any local truck stops in your area? If so they typically sell SWR meters. Also some Radio Shack stores still stock SWR meters. You will also need a short piece of coax cable to use as a jumper.
Hey JK505., which Cobra 29 do you have?
Some models have a little red light that comes on when the SWR is too high. Does yours?
Also, what does the S/RF meter show when transmitting? Does it show a constant reading or does it drop off?
I believe it reads 3.2ish when transmitting. I'll check in the morning to confirm. And it's a constant reading when transmitting, no drop off.
Definitely seems like a grounding issue. Are you still using the SWR on the radio? Do you have someone who can help out by grounding it while you check the SWR?
Yes still using the meter in the radio. Only option I've got for now, unfortunately. I don't have anyone who can ground it (I assume you mean by touching the antenna) but I do have about 3,000 feet of copper wire! If someone can tell me how to ground the antenna, ie where to attach the antenna end of the wire, I can take it from there. (Former Electrician by trade)
I'm supposing you already read the manual -
https://www.cobra.com/sites/default/...s/29LTDCLA.pdf
If you have the switch in the S/RF position and the meter swings all the way to the right AND when the meter is set to the SWR position and it reads less than 3 then you should be good to go.
PS> I grounded my tailgate to the body of the Jeep. There is a bolt on the right side of the back that I used for one side of the ground and then I ran the grounding wire near the hinge up thru the tail gate to the antenna mount.
