AntennaX CB Antenna and ProComm Im-AF Splitter?
Has anyone installed a ProComm Im-AF Splitter and a replacement antenna? I'm curious if this is just a gimmick or if one can actually get good radio and CB reception from the same antenna.
It will probably work, but not as well as an antenna tuned to the frequencies desired. If your communication mode is line-of-sight (or less) then it might be worth it. If you want to utilize the maximum capabilities of your transceiver, then it's not so good.
