Best cb radio for the money
Old 01-04-2014, 12:09 PM
  #41
robsjeep9's Avatar
Originally Posted by hunterm
Awesome! Thanks for all the help! And what length antenna are you running?
Wilson 4' ..........
Old 07-28-2014, 06:40 PM
  #42
mousespecial14's Avatar
I like the Cobra 29 radio because it has extra features like timer, alarm, and clock capabilities . It's rated #1 here 5 Good 40 Channel CB Radios 2014 .
Old 07-29-2014, 07:26 AM
  #43
Skotler75's Avatar
I just bought the Cobra 29 LTD. It has a built in SWR meter and it is as easy as tying your shoes to tune the antenna to it. I used it at Rausch Creek this past weekend and it worked flawlessly. Its about 100 bucks on Amazon.com.
I had no electrical background before this install. I bought a couple crimping connectors and solderless ring connectors and shabam... had myself a working cb radio. The only thing that was tough was soldering the firestik firering coax connection. With some quick youtube tutorials, i flawlessly soldered the cable to the coax connector.
EDIT:: There is also a step by step install write up from WayaLife- http://wayalife.com/showthread.php?5...ation-Write-Up
Old 07-30-2014, 06:43 PM
  #44
bolverk's Avatar
I absolutely love my Galaxy DX979... I'm running a 250watt linear as well. Gonna swap it over to the Jeep before hunting season kicks off. Anyone know if the JK has any issues with amped CB setups? Interference with ECU? electronics?
xMikeD (06-28-2021)
Old 08-28-2018, 11:17 PM
  #45
Stacy Johnna's Avatar
Quansheng UV-R50 is te Best CB radio i have ever experianced.
Old 08-29-2018, 06:09 AM
  #46
caryt's Avatar
This one, read all the reviews.
https://www.amazon.com/AnyTone-Smart-Meter-convert-Channel/dp/B0140QP3VU
Old 09-04-2018, 09:25 AM
  #47
cranbiz's Avatar
I run an Anytone Apollo 1 now and can switch between 10m and 11m but I also have a Ham license that covers 10m
I like it because it's a controls in the mic, has an internal disconnect when an external speaker is plugged in and the base is small enough to hide in a lot of places.
I had a Bearcat 980 prior to it and that is a fine radio also but in my interior redesign, it was just too big.
I decided against the Uniden all in ones because of the lack of speaker disconnect and against the Cobra 75wxst due to the cords falling apart and the difficulty in obtaining and replacing the cord.
Old 12-24-2020, 05:38 AM
  #48
Jeepr Keeper's Avatar
As I use CB radios mainly in my Jeep Wranglers, I find any Jeep CB radio on the Walcott online store appropriate for my off-road needs.
Old 02-17-2023, 01:09 AM
  #49
cyrus799's Avatar
Using this Midland CB radio, I truly like having easy communication when traveling. It is the result of cutting-edge engineering and is loaded with unique features.
It's important to note the strength of this CB radio for Jeep Wrangler JK and other makes and models. Its full 15-watt output contributes to dependable performance. Aside from that, its magnetic antenna mount enhances radio communications. It is simple to fasten to the trunk, roof, or other places.
Quick Reply: Best cb radio for the money
