Can a lift kit effect CB tuning?
If I get my antenna tuned, and it works great, and then I install a lift kit and bigger tires, am I messing with the tuning? In other words, does putting the Jeep (and thus the antenna) higher in the air effect the tuning? Or is it just the placement/grounding/etc, which doesn't really change when you raise the jeep?
Thanks!
Thanks!
If I get my antenna tuned, and it works great, and then I install a lift kit and bigger tires, am I messing with the tuning? In other words, does putting the Jeep (and thus the antenna) higher in the air effect the tuning? Or is it just the placement/grounding/etc, which doesn't really change when you raise the jeep? Thanks!
