CB Wiring Question
CB Wiring Question
Ok, I'm completely ignorant when it comes to wiring. I'm wiring my Uniden 980 today, and although the wiring says to go straight to the battery, I'm thinking I'd rather have it so that it only works with the ignition on or in accessory mode. How would I wire it to the fuse box to get that, or is that not the best way to go? I've already got the wires run through the firewall. I have to extend them about a foot or two to get to the battery or fuse box, so that's no big deal.
Then again, maybe I keep it simple and just go to the battery.
Suggestions and advice are welcome! Thanks!
Nothing wrong with having it switched. Just personal preferences. Theres a few ways of doing this. If your not using your cigarette lighter port for anything splice behind it. Or use that same source to trigger a relay. Or use this Quadratec Exclusive JK-APT2011 - 12 Volt Power Adapter for 99-15 Jeep® Wrangler TJ, JK , TJ Unlimited & Wrangler Unlimited JK - Quadratec
Add-A-Fuse Mini/ATM Fuse Tap
They carry these at most your local auto parts stores, as well as Wal Mart and elsewhere. I used one of these to activate the relay for my OBA setup. The lead runs out of the fuse box though, so you have to notch the box a little to allow room for the wire to get out. Easily done with a utility blade or Dremel or something.
Multiple ways to wire to switched power as you can see, but to step back, I thought I'd read in several places that wiring directly to the battery was preferable due to the potential for some interference or 'whine' in the CB audio if you go the switched route. I wired mine directly to the battery because of that theory. Sometimes it's annoying that it can stay on while the ignition is off, but I only use the CB off-road anyway, and I tend to remember to turn it off as I transition to on-road, like airing back up, etc. Just thinking out loud.
Wow, thanks for all the options! I never heard the interference deal, but my cautious nature may make me lean that way.
I can't wait to get this thing fired up! I've got to go and pick up a long antenna cable, then I'll be ready to go. What gauge is the wiring from a Uniden CB? I've got to extend it by a foot or so, to get to the battery or the fuse terminal.
It can be a little tricky to match wires up visually since they often times have different sized protective coating. I've seen two wires that appear to be the same gauge, but when you look at the copper wire itself, it was obvious that one was a thicker gauge while the other just had more coating around it. I'm not referring to this case in particular, because he's only talking about adding a foot, which is nothing really. I'm just saying in general.
