Cobra 75 WX ST Install
This is how I installed a Cobra WX ST in my 2014 JK.
First a list of parts:
Cobra WX ST
2$ 12 volt plug for power from Wal-Mart
18 foot antenna cable
Terraflex spare tire carrier mount
Antenna mount (not sure what it's called the antenna and cable connect to it)
Antenna quick disconnect
3" firestick
Step 1 - Remove the spare tire, and the two top right bolts. They will be replaced with the ones from terraflex.
Step 2 - Attatch the spare tire carrier mount.
Step 3 - Attatch the mount and quick disconnect.
Step 4 - Connect the cable and run it through the roll bar. I left the hard top on which made the zipper really dissicuilt to get unzipped above the speaker bar. You may want to remove the hard top for this if you have one.
Attachment 563855
Note: I ran my cable through the trim on the back hatch which pops off easily from the bottom. I think it looks clraner.
Step 5 - Install the antenna
Step 6 - Install the cb base unit under the seat console or dash. You can run the antenna cable down from the roll bar along the passenger side trim without removing it. The panel to the right side of the dash pops off no screws needed. Also the glove box lifts out if you pinch the top back sides inward.
Finally wire to a 12 volt adapter as shown in the first pic, and your done.
Attachment 563862
Cobra WX ST
3" firestick
Attachment 563855
Attachment 563862
I hope you sanded/filed the paint from where you attached your antenna to the mount. If not, you're gonna have some SWR issues from a poor ground. Might as well detach the antenna and do it right- save your radio and make yourself more audible to your buddies on the trail.
I run this setup and didn't sand/file anything. My SWR readings are 1.2 for ch. 1 and 1.3 for ch. 40....not too shabby. I run my cable along the floor under the carpet though, so no idea if that makes any difference. Just gotta make sure your ground is good and you're not coiling leftover coax cable. Not sure why you're sanding/filing anything.
