cool tech ground
Old 05-02-2012, 11:20 AM
slappygoeshome's Avatar
Default cool tech ground
what are you guys doing with the short wire? i already ran the wire through the tail gate and would hate to take it all apart could i go get another wire and connect them? what gage wire is that also the firefly is hitting the tire? just leave it? im sure both topic s have been hit on i cant find them tho sry
Old 05-02-2012, 11:29 AM
MTG
MTG's Avatar
I ran it through the grommet with the intent of grounding it to the sub mount per the instructions. However, I never did and the CB worked fine without it grounded. So it just sits there for now.
Not sure about your other question.
Old 05-02-2012, 12:06 PM
the antenna is flexing off the tire......i would assume this is a common promblem with the stock tire mount
Old 05-02-2012, 04:16 PM
pderr676's Avatar
A friend helped me install that kit a couple of months ago. He had the same cb. We did not connect the supplied ground wire and my cb works just fine. The stock spare does cause some deflection, but this does not affect the performance of the cb. All of the receiving and broadcasting occur at the tip of the antenna.
Quick Reply: cool tech ground
