New to CB radios
We just installed a Cobra 75 WX ST and it works great. The handheld system, similar to the Midland, eliminates the need to mount a large box somewhere. We put an install video together, too. Check it out!
https://youtu.be/c3CgK3uTWkI
http://www.quadratec.com/products/96080_9801.htm
We just installed a Cobra 75 WX ST and it works great. The handheld system, similar to the Midland, eliminates the need to mount a large box somewhere. We put an install video together, too. Check it out! https://youtu.be/c3CgK3uTWkI
http://www.quadratec.com/products/96080_213.htm
It's a much cleaner job to tie in to an accessory power supply. Not to mention, we don't have any loose wires running directly from the battery. When we shut the jeep off, the CB system will shut off as well, rather than becoming a parasitic drain if we forget about it and leave it on. The dash is VERY easy to remove in the 2011-Current JK. It requires a single flat-head screwdriver and a 7mm socket. Without pausing to record a video, we can pull the whole thing out in just around 5 minutes.
