Uniden 880 problems
Old 01-27-2013, 02:13 PM
Nibsirb's Avatar
Default Uniden 880 problems
I hooked up my cb and I get some traffic on the channels but def nothing major. I live literally right next to the interstate so I assumed I'd get a bit....when I transmit I get no replies. Built in SWR shows 1.00 for all channels. I tried hooking up a ground wire hoping that would help but when I do my RF and Antennae checks fail????? I remove the ground and everything checks okay. Not sure what's going on.... should I try buying a SWR meter and go off that rather than the built in? No sure...
Old 02-07-2013, 06:54 PM
Marmot mb's Avatar
Check you have grounding on the correct side of antenea mount. Buddy had this issue flipped mounting peices around and worked fine. He could hear a bit but noone could hear him.
Quick Reply: Uniden 880 problems
