rugged Ridge cb mount
Had anyone have had issues with this mount for 2010 and under drilling through the top hard top latches? It just seems sketchy drilling it
I just figured it out it tells you in the directions to drill for 2010 and lower jk but that is untrue. Just Re use th bolts and apply thr mount like you would if you had a 11 and up jk. Worked out great cor me. But I ripped th antenna end cable off the wire by accident can you tell crimp it without replacing the entire wire?
