Which wire to tap for Dimmer
I am wiring LED rocker switches to my A pillar switch pod and the switches have 5 pins. One of the pins is supposed to connect to power (dimmer switched power recommended) so that switch will be constant lit when the headlights/parking lights are on. Has anyone done this? Is it best to tie into that wire behind the climate controls? Or the Power window controls in the center of the console? I have four switches that need this power. Is it ok to tie them all into one wire with 4 taps? one wire spliced to four switches or should I try and find 4 separate locations to tap into?
Any help is appreciated.
Thanks,
Thanks,
