2007 JK Does not turn off
Alternator is new
Replaced it when I replaced the ignition cylinder and the 2nd ignition switch. Where can I get a schematic of the ignition/ignition switch so I can locate the neg ground fault? Battery positive goes straight to the TPIM, so I need to trace it from there with my multimeter through the system. BTW, when I disconnect the PCM, the electronic system is on. Dash lights up, so it's getting the positive via a ground fault before the PCM or it's coming directly from the TPIM.
All good. I did not mention before because I did not think it was relevant since it was new. Question: which of the 4 wires on the ignition switch connector should be hot when the battery is connected and which ones should be dead? It's hard to trace without a decent schematic and I can't find one online. I am trying to figure out if the "on/run" is already hot at the connector when it should be cold/dead. That will give me a good point of reference to start looking for the neg fault.
Wires in the ignition switch connector:
1 Ground
2 Ignition Switch Sense to the WCM
3 Ignition Switch Output Run/Start to the WCM and the TIPM circuit board
4 Unused
5 Power to the switch from the battery bus through fuse M27
1 Ground
4 Unused
What's the History of this Rubicon, as in, flood, accident, traumatic events. Flooding could certainly lead to corrosion of harness connectors, something to explain this interesting problem. Leave no stone unturned. There's always more to the story
