2011 - 2012 switched 12v power and dash light power location???
Old 01-07-2012, 06:14 AM
phouck's Avatar
Default 2011 - 2012 switched 12v power and dash light power location???
I'm in the process of installing my ARB compressor and need switched 12v power and dash light power for the switch. I'm mounting the switch in a daystar switch panel below the hvac controls. I've removed the original panel in this location, but there are no wire harnesses accessable behind it like in previous model years. Anyone have any luck locating a good source for these and if so, how do you get to them?
Old 01-07-2012, 06:17 AM
Grimmjpr's Avatar
I just did this install, finished last nite. Sorry i cant help with the wiring, I installed a simple covered rocker switch under the hood since i have to open the hood to attach the hose anyway......hope you get yours sorted out. Its a really nice set up.
Old 01-07-2012, 06:18 AM
ronjenx's Avatar
Give this a try. See if your TIPM is set up like mine.
https://www.jk-forum.com/forums/show...d-Power-Source
https://www.jk-forum.com/forums/show...y-Power-Source
Old 01-07-2012, 08:48 AM
phouck's Avatar
Thanks, but im really looking for something to splice into inside the cab.
Old 01-07-2012, 08:58 AM
ronjenx's Avatar
That's OK.
You are not the first to prefer removing part of the dash and splicing rather than having an easily installed, dedicated, fuse protected line right out of the fuse box.
Old 01-07-2012, 10:05 AM
phouck's Avatar
I understand what you are saying; however, your solution doesn't take into account the second part of my problem which is the dimmable dash light power source. I'm most likely going to have to take apart the dash to some level to get to this wire anyway, so rather than running additional wire to the TIPM, I could just splice into the Power Outlet that is fused at M7 anyway. The additional load used to actuate the relay in the ARB system would have little affect on the Power Outlet circuit, and wouldn't limit my ablity to use both at the same time, if that ever happened.
Old 01-07-2012, 12:26 PM
ronjenx's Avatar
I guess I didn't include "dimmable" in my mental picture of what you are wanting to do.
Old 01-09-2012, 07:41 AM
phouck's Avatar
No problem "ron". I like your clean install for getting switchable power and will likely use it in the future. For this application, I did disassemble the dash, which isn't all that difficult, and used my multimeter to find the dimmable dash light wiring that I needed. I spliced into the Blue w/ purple wire coming out of the cig lighter for switchable power and into the orange w/ grey wire coming from the electric mirror control for dimmable light. Now, my switch lights up when the headlights are turned on and are dimmable with the rest of the dash lights.
Old 01-09-2012, 05:08 PM
ronjenx's Avatar
That's good to know the dimmable circuit will handle extra lights.
Quick Reply: 2011 - 2012 switched 12v power and dash light power location???
