430N backup camera
#284
430N backup camera problems with a 2015 JKU Rubicon
However, I've run into a problem where, while I get the 'Check Surroundings' warning message, all I can see on the display is a black screen.
I've tried two different cameras, with the same result.
Any help or input on how to solve this would be appreciated.
Thanks
Taren
#285
#286
I was also able to get my 430N flashed by my dealership for no cost.
Thanks
Taren
Thanks
Taren
#287
Not sure which camera you are using. I went through a couple of the cheap Ginos that were basically new and DOA. I was able to use an old digital camcorder, which obviously runs off a battery pack, to at least get an image on screen and check my video wiring integrity and verify dealer headunit flash took. Once that was confirmed I knew the problem was on the camera end. The wires on the cheaper cams are very fragile easy to damage small gauge wires, So even the act of installing can mess them up if you arent very careful. I opted to buy a higher quality name brand camera and it worked right since install.
#289
Here is the camera i got and it work great. In the beginning of the thread all the products to use were listed.
http://www.amazon.com/gp/product/B00...=sr_1_1&sr=8-1
#290
got my camera installed i had adjust the camera to square it up with the back of the jeep. i think the camera was crooked in the housing, cheap camera.
just 2 days after getting it hooked up its starting to track on the screen... the image scrolls from top to bottom for some reason, anyone know why? besides its being a cheap pos from china? should i order a new one?
