430N backup camera
Old 04-17-2014, 10:58 AM
  #91
relyt's Avatar
Originally Posted by Divi
Tail light ground wire.
Are you using the factory reverse bulbs? Now I'm wondering if the LEDs I have installed may be introducing feedback in to the circuit.
Old 04-17-2014, 12:44 PM
  #92
GADozer's Avatar
I have the same camera and it has a great image. I'm grounded to the reverse lamps with stock bulbs.
Old 04-17-2014, 04:57 PM
  #93
Divi's Avatar
Stock bulb. Do you have a resistor in line? If so might want to tap power off the trailer wore harness. Hear there is wiring for the 7 pin down there somewhere that you can tap the reverse from.
Sent from my XT1080 using Tapatalk
Old 04-17-2014, 07:06 PM
  #94
relyt's Avatar
No resistors. I messed with it a little and now it's crystal clear. I think my ground may have been a little loose. I still have to pull my dash back apart to update the software on my NavTool, but the reverse camera works great now.
Old 04-21-2014, 02:48 PM
  #95
SMSgt B's Avatar
Thanks to this thread, I completed the install yesterday. It wasn't as hard as I thought it was going to be, but I dove in as prepared as I could be. Tomorrow I'm having the dealership Star scan my 430N, so I'm not sure if I did everything correctly yet ... hopefully I did. Here are a couple pics that I was unable to find when doing my homework. Please let me know if I did something wrong.
I assume this is where you connect into
I removed the glove box and routed the wiring harness up through the left side. The RCA cable for the camera I routed back along the firewall so I could route it under the carpet along the passenger side
I wrapped up the remaining wires and tie strapped them up so that the glove box would not hit them.
I used the drill bit that came with the camera to get through the bumper. Then I used a regular drill bit just a little smaller to drill the back part of the bumper
I did loosen the 2 bumper bolts which gave enough clearance to router the camera RCA connectors up and over the frame, then into the back area.
Old 04-24-2014, 06:19 PM
  #96
JAustin's Avatar
I'd be curious to learn what your dealer charges you for the StarSCAN programming. I just contacted my closest dealer (not where I purchased the vehicle), and the Service Manager quoted me $105 to reprogram my 730N. Seems high to me, based on other posts I've read.
The dealer where I bought the Jeep is further away, but I'm going to check with them tomorrow.
Old 04-24-2014, 07:12 PM
  #97
GADozer's Avatar
$52.00 for my 430
Old 04-25-2014, 04:03 AM
  #98
Tmjeep's Avatar
Default 430N backup camera
Just got mine done yesterday for free while it was there getting undercoating done.
Old 04-25-2014, 04:59 AM
  #99
JAustin's Avatar
Originally Posted by GADozer
$52.00 for my 430
Originally Posted by Tmjeep
Just got mine done yesterday while it was there getting undercoating done for free.
Thanks for your feedback. I thought I had seen prices in the range from $0 to $50 in previous reading, but didn't want to have to track down all those messages.
So apparently my closest dealer is either clueless, trying to gouge me, or just making sure he doesn't commit to doing something at a loss.
The dealer from whom I purchased the vehicle is further away, but has a much better reputation. It'll be interesting to hear what they have to say.
Old 04-25-2014, 06:23 AM
  #100
sea bass's Avatar
Originally Posted by JAustin
Thanks for your feedback. I thought I had seen prices in the range from $0 to $50 in previous reading, but didn't want to have to track down all those messages. So apparently my closest dealer is either clueless, trying to gouge me, or just making sure he doesn't commit to doing something at a loss. The dealer from whom I purchased the vehicle is further away, but has a much better reputation. It'll be interesting to hear what they have to say.
I got two $65 quotes and one $125 quote around Seattle.
Quick Reply: 430N backup camera
