430N backup camera
Old 02-26-2014, 05:35 AM
  #21
Divi's Avatar
Amazon.com: Gino 1/4" CCD Flush Mount Waterproof Truck Car Reverse Backup Rear View Camera: Car Electronics
Works well at night and great during the day.
Old 02-26-2014, 05:36 AM
  #22
Divi's Avatar
Mines a smidge off center make sure you measure instead of eye ball like I did before you drill.
Old 02-26-2014, 07:45 AM
  #23
Tmjeep's Avatar
Thanks again!
Old 02-26-2014, 09:15 AM
  #24
Bobby D.'s Avatar
So with that harness and camera, would the only other material needed be a fuse tap to power the camera? No cutting the factory wires at all? I assume once the radio is programmed...it will look for the camera when the tranny is shifted into reverse? Since I don't tow with my jeep, I want to have the camera mounted in the receiver hitch in a removable insert. Does it seem like this would be high enough to foe a decent view?
Old 02-26-2014, 09:35 AM
  #25
Divi's Avatar
I would tap the camera power off the drivers side tail light. Receiver hitch would work.
Sent from my XT1080 using Tapatalk
Old 02-26-2014, 09:54 AM
  #26
Bobby D.'s Avatar
Definitely a rookie question here...how do you get the power from the tail light without cutting any wires? I don't want to give the warranty nazis any reason to blame me for future failures of the factory parts.
Thanks.
Old 02-26-2014, 10:27 AM
  #27
chuckt62's Avatar
I think most people just splice in with a ScotchLok, but if you're worried about "touching" the harness you can pick up the trailer hitch harness and us it.
Old 02-26-2014, 10:52 AM
  #28
Bobby D.'s Avatar
Follow up rookie question...is that enough to power the camera or does that need to trigger a relay that supplies the power?
Thanks again!
Old 02-26-2014, 10:56 AM
  #29
Divi's Avatar
Its enough to power. I'm tapped into the reverse light and works fine.
Old 02-28-2014, 07:25 PM
  #30
Bobby D.'s Avatar
In the kit that is sold or the grand Cherokee and commander, I think there are two wires that are plugged into the back of the radio. Is this the camera video signal and power or do they have to tap the reverse light as well? I like the idea of using the trailer hitch wire but the two packages only come with 4 pin plugs...that's brakes, l/r blink and ground right? Which of these is used for reverse light power?
Thanks for the help.
bd
Quick Reply: 430N backup camera
