50" Rough Country Light bar Bracket with other led bars
Old 07-29-2014, 10:24 AM
PANGMAN's Avatar
Default 50" Rough Country Light bar Bracket with other led bars
Has anybody purchased the Rough Country 50" light bar brackets and run other Led Light bars other than the Rough Country Light bar. Let me know which ones you used and the links if available.
Old 07-29-2014, 10:51 AM
Fugg it's Avatar
All of the lightbars are the same and from china. Even the 54" ones are 50" bars and size included the shitty mounts that come with the lightbars lol. You'll be fine.
I believe the only ones that have issues are the curved bars due to the ends being angled as a result of the curve
Old 07-29-2014, 04:55 PM
liverocity's Avatar
I run a 52 inch on there. Took a little coercing and longer bolts to hold mounts to jeep but it works fine.
Old 07-29-2014, 05:07 PM
PANGMAN's Avatar
Was this an ebay one? Eyourlife?
Old 07-30-2014, 05:48 PM
8000ft's Avatar
I'm using them with an eyourlife 300w bar. the 300w bars are 52" wide at the mounting surface whereas the 288w bars are actually 50" wide at the mounting ends.
If I had known that a 50" 300w bar was 52" I would have found a 288w.
Old 07-30-2014, 07:54 PM
liverocity's Avatar
I got mine on amazon less than 200 shipped.
Old 07-30-2014, 08:05 PM
stoova's Avatar
link?
Old 07-30-2014, 10:09 PM
Former Vendor
Sami@inspired-engineering's Avatar
We tend to recommend and sell the Rough Country brackets with our light bars.
No all light bars are the same though, and not all are the same width as posted above. Some bars are wider and will stretch the brackets out. Some are a bit thinner and will require spacers or washers along with longer bolts.
Old 07-31-2014, 04:59 AM
PANGMAN's Avatar
Yeah. Thats what I thought. That's kinda why I wanted to see what others had tried. I'd probably opt to have it slightly short and adding spacers and longer bolts than trying ro make one too wide to fit.
Quick Reply: 50" Rough Country Light bar Bracket with other led bars
