50" Rough Country Light bar Bracket with other led bars
Has anybody purchased the Rough Country 50" light bar brackets and run other Led Light bars other than the Rough Country Light bar. Let me know which ones you used and the links if available.
All of the lightbars are the same and from china. Even the 54" ones are 50" bars and size included the shitty mounts that come with the lightbars lol. You'll be fine.
I believe the only ones that have issues are the curved bars due to the ends being angled as a result of the curve
I'm using them with an eyourlife 300w bar. the 300w bars are 52" wide at the mounting surface whereas the 288w bars are actually 50" wide at the mounting ends.
If I had known that a 50" 300w bar was 52" I would have found a 288w.
Former Vendor
We tend to recommend and sell the Rough Country brackets with our light bars.
No all light bars are the same though, and not all are the same width as posted above. Some bars are wider and will stretch the brackets out. Some are a bit thinner and will require spacers or washers along with longer bolts.
