Adjusting Truck-lite Headlights
Just installed some Trucklite LEDs and need to adjust them. I have the Rugged Ridge trim rings in the grill and I can't see the adjustment screws fully. Are they Phillip heads, Allen heads, or what? I could pull the grill off again but that would be too easy. Also for adjusting them vertically would I use the inboard or outboard screws? Thanks............
They are torx head T-15. The sliver one at the bottom. This is my horizontal adjustment screw on the driver side but they look the same.
The vertical adjustment on the driver side is at about 2'clock, on the passenger side is at about 10 o'clock.
Ah, great - same as the retaining ring screws.
EDIT: Got it, and thanks sbxjunkie. Drivers side was way off vertically.
