Amp draw of led offroad lighting?
Old 11-26-2014, 11:38 AM
spanky1989's Avatar
Default Amp draw of led offroad lighting?
Does anyone know where I can find what amperage an led offroad light/led bar/ spots and such draw? Working on my own version of a relay box and I'm looking into using the smaller relays that can handle 10/20 amps. I have a feeling that I'll be ok doing 2 lights per circuit but want to be sure before I get too far into it. Thanks for any info or advice.
Old 11-26-2014, 11:43 AM
spanky1989's Avatar
Here is the relay style I'm looking to use.
ID:	585763   Click image for larger version
ID:	585764   Click image for larger version
ID:	585765   Click image for larger version
Old 11-26-2014, 04:37 PM
JTB488's Avatar
It should be on their site. All depends on which one's you pick. Small cubes vs 50 inch bar. I have some small Rigids and Cubes from Inspired Eng and they draw less than 2 amps.
Old 11-26-2014, 05:30 PM
Vladimer's Avatar
It all depends on the size of lights you have.
Here is a handy converter - Volts/Amps/Watts Converter
Old 11-27-2014, 03:34 AM
14Sport's Avatar
Amps = Watts divided by Volts. (A=W/V).
So if you know the watts of the lights, you can easily calculate amps.
For example, a 55W light would draw 4.58 (55/12) amps. A pair of them would draw 9.17 amps.
Things to keep in mind:
1. Many lights come in pairs so you have to use the combined amps if they are running off the same relay.
2. Generally you want a relay that is rated around 20-25% higher than the draw.
3. The alternator puts out greater than 12 volts. However, I always use 12V in my calculations (many use 13.8V) because it gives a built in safety factor.
So for me, the most I would run on a 20A relay is 16A (20A x .8).
Based on that, the maximum wattage for lights on a 20A relay would be 192W (16A x 12V), again for me.
If you use 13.8V in your calculations, then it would be 221W.
Steve Scaper SAS (05-14-2021)
Old 11-27-2014, 06:25 AM
spanky1989's Avatar
Thanks for the feedback. I already new about the math to find current, I just wasn't sure if it was the same for an led. Many LEDs put out a higher wattage of light than the standard bulb, so I thought there might be a different formula. I guess I'll just have to look into which lights I want to go with and go from there. Thanks
Old 11-27-2014, 06:27 AM
spanky1989's Avatar
It would also be nice if I could get my amp meter attachment to work on my meter.
Old 11-27-2014, 07:55 AM
stagedtrip's Avatar
10 characters
Old 11-27-2014, 08:40 AM
14Sport's Avatar
You're on the right track, but it's lumens not watts that are different. The LED uses much less wattage (approximately 1/4) to produce the equivalent lumens of halogens. So a 10W LED will produce the equivalent light (lumens) as a 40W halogen. A 40W halogen will draw 3.33A (40/12) while a 10W LED will draw .83A (10/12) to produce the same amount of light. But whatever the watts are still determines the draw, with voltage of course.
Old 11-27-2014, 03:21 PM
spanky1989's Avatar
Oh ok that makes sense, so the average 55w led will be equivalent to a 200 something watt halogen. From what I'm gathering I should be alright with the 10/20 amp fuses for led lights. I'll obviously use the regular size relay spot for onboard air when I get to it. Anyone have any opinions on what kind or relay control wiring to use from the switches? I was thinking about the cat5 cable route.
Quick Reply: Amp draw of led offroad lighting?
