Android 4.3 issues with Uconnect
Moderators, please consider making this a sticky:
Android 4.3 issues with Uconnect and the following radios:
RES, REQ, RBZ and RHB
I have recently run into an issue with Samsung phones using the Android 4.3 SW. This issue is with new phones as well as phones that have been updated from the Android 4.2 and are on the CDMA networks (Sprint & Verizon). Phones that have been updated from the 4.2 version have been working well till the update was applied. It most likely will be on other CDMA networks as well.
*** I have tried the HTC ONE with 4.3 and it did not have the issue. ***
Here is what happens:
You attempt to place an outgoing call using Uconnect, the call will start the outgoing call and then you’ll hear “Call Completed” but the call is still active on the phone itself.
This is an issue with the phone and network which is currently being looked into by Samsung.
Hmm, This is getting more and more interesting. I just spoke to another person with the 730N radio (which I don't have) who has the same issue since he recently updated his phone. Now you're saying that you have this issue on a BT headset, (correct?) May I ask which phone you have and the network that you're on? Thanks.
As I mentioned in the title:
Android 4.3 issues with the following radios:
REQ, RES, RBZ & RHB. The 730N is not one of these radios, so I would expect that you're not having this issue. I found the post from a person a different forum with the 730N to be interesting but I could not personally verify it because I don't have access to it.
Which radio do you have and where are you talking about not seeing the BT selection being highlighted?
excuse me for asking but I'm just not clear on this. You said that you haven't been able to catch it in the vehicle, are you saying that it does not happen over your Uconnect at all?
