Audio Build - 2016 2 Door (Hertz, Arc, Sundown, Morel)
Old 11-15-2016, 10:48 AM
  #31
DavidRam's Avatar
Originally Posted by Mattk11
A few questions. I see that stealth is not a concern and you will swap out tweeters whenever you take the top off.
Did you move the tweeters up out of the dash so they were more focused at the listener, for looks or to free up the 4" dash opening for a midrange so you could go 3-way?
Did you keep the Hertz mid-bass speaker or is this a tweeter replacement only?
Why the multiple round holes in the plexiglass base?
Is your amp rack inside the storage area in the back?
This is really nice fabrication work, keep it up!
Thanks man!
I moved the tweeter to the dash in an attempt to fix the issues I was having with the windows down - the center would wander and the sound would get washed out, especially the highs. Putting the tweeters more on axis has helped tremendously with those issues. Plus, the Milles are a much brighter tweeter and with the in-dash placement the reflections were hurting the imaging as well.
I have often thought about doing a 3way, but for now I am quite happy with the sound as a 2way with rear fill.
I have actually been running Morel's Hybrid MW6 midbass for a while now...
These Morel tweeters are very laid back and smooth. With only the slightest EQing they sound amazing!
Actually, the holes are not in the plexiglass itself, but just in the vinyl I wrapped them in, to allow light through (see pics).
The amp rack is on top of the Tuffy security cover, though I did put a cover over it to not attract to much attention...
ID:	660921   Click image for larger version
ID:	660922   Click image for larger version
ID:	660923   Click image for larger version
Old 11-28-2016, 09:50 AM
  #32
DavidRam's Avatar
Well, as usual I just can't leave well enough alone... I decided with all the aluminum in the cab, I would like the tweeters to be in aluminum pods...
So I ordered these from Germany, they are custom made for the Morel MT250s...
ID:	661761   Click image for larger version
ID:	661762   Click image for larger version
Old 12-05-2016, 12:16 AM
  #33
twise's Avatar
I always hear people say, "you can't have good sound in a jeep". Thanks for demonstrating that this is a myth. With the right amount of knowledge and the proper equipment, a shopping cart can be made to have the best sound ever. I like the pods. Those are sick.
Old 12-05-2016, 07:03 AM
  #34
DavidRam's Avatar
Thanks man! Looking forward to getting the pods in and installed...
Old 01-16-2017, 06:35 AM
  #35
DavidRam's Avatar
I got the pods installed, really happy with them. Interestingly, aimed as they are the stage depth is noticeably better.
ID:	664561   Click image for larger version
ID:	664562   Click image for larger version
ID:	664563   Click image for larger version
ID:	664564   Click image for larger version
Old 01-18-2017, 11:23 AM
  #36
DavidRam's Avatar
Better pics
ID:	664851   Click image for larger version
ID:	664852   Click image for larger version
ID:	664853   Click image for larger version
ID:	664854   Click image for larger version
ID:	664856   Click image for larger version
ID:	664857   Click image for larger version
Quick Reply: Audio Build - 2016 2 Door (Hertz, Arc, Sundown, Morel)
