AVIC-8000NEX - Install Help Needed
Good day everyone. Newbie at the head unit install. Looking for a little help/guidance.
So I've purchased the Pioneer AVIC-8000NEX with the Metra 95-6511 Dash Kit. I've screwed them in to each side and for some reason I can't seem to get the HU to fit in properly. Are there any mods I need to make to the sub-dash or even the dash itself. Any help is truly appreciated.
Thanks.
Thanks.
Thanks for the quick reply. That metal harness/bracket in the back, did you remove it completely or hack away at it with a dremmel tool? And the jeep is a 2011 Wrangler Unlimited. The Metra Dash kit seems to be hitting the top of the sub-dash. Pics coming in a few.
Mines 2008. I unbolted and removed completely
I tired and it doesn't screw into the HU properly. I think I'm going to dremel a little bit of the plastic off the dash kit. I don't want to mess with the integrity of the actual sub-dash itself. Glad I'm learning as I go but man is this ever disheartening. Gotta keep telling myself it'll be worth it in the end.
I had to dream ill the bottom lip of the plastic piece where your box is for a pioneer avh 8500 (forget the model # exactly). Fit perfect after. I made sure to keep as much plastic as I could on the middle plastic piece
