Big 3 wire upgrade
Big 3 wire upgrade
Looking at upgrading the power wires..
Here is the plan
1/0 gauge - Power & Ground Wire
Alternator (+) ---> Battery (+)w/ 250 amp ANL Fuse
Alternator Mounting Bracket ----> Battery (-)
Battery (-) ----> Body Ground
Alternator Mounting Bracket ----> Body Ground
Am I missing anything?
Here is the plan
Sounds good then. I recomend that you use something like this on the connections. \/ \/
http://www.tessco.com/products/displayProductInfo.do?sku=26727&eventPage=1
You should be able to find something like this at any outlet that sells electrical supplies.
Fritz_2021 (04-05-2021)
