Bypassing Ignition key chip
Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    JK Junkie AlmightyCrash's Avatar
    Join Date
    Jul 2008
    Location
    Tyler, TX
    Posts
    2,509
    Default Bypassing Ignition key chip
    anybody know where I can find instructions on how to bypass this?
    the way I see it, its just a box with a chip to acknowledge the chips presence.
    If it is all run through one harness, I should be able to jump harness points to make it think it was there.
    i keep getting error codes for it, and cant afford to do anything with it.
    TONKA H2O-SURF SHARK
    Crashbuilt Custom Snorkel
    Black Diamond 3inch Lift Kit
    Bushwacker Flares/ AEV Hood
    BFG KM2 325/60/R20 (36x13.5)
    ( lllllllllllllll )
    l_MK 1:12_l
    COP4x4_ _ _ _ _ _ _ _ _ _ _ _ LOD SS
    CARGO _ _ _ _ _ _ _ _ _ _ _ _ _ GEN 2
    NACK_ _ _ _ _ _ _ _ _ _ _ _ _ _ REAR
    ATTACK_ _ _ _ _ _ _ _ _ _ _ _ _BUMPER
  2. #2
    Banned Sethc84's Avatar
    Join Date
    May 2009
    Location
    Long Island, NY
    Posts
    204
    Not exactly sure where it is but there should be an antenna around the ignition maybe trace it back? The best person to ask would be someone who does aftermarket remote starters. They know exactly where it is to tuck a transponder key in. Hence why they ask you for a key when they put an aftermarket alarm/starter in.
  3. #3
    Join Date
    Jul 2008
    Location
    Tyler, TX
    Posts
    2,509
    thanks.
    I know where it is, im looking to disable the requirement for it.
    ( lllllllllllllll )
    l_MK 1:12_l
  4. #4
    Join Date
    May 2009
    Location
    Long Island, NY
    Posts
    204
    The requirement for it is in the computer. You would need to re-flash it, if that is even possible.
    Come to think of it, being as your jeep was under water, that just may be a code you are seeing due the computer being 'fried' or it may have lost the programing for your transponder. Solution to the second possibility would be to have the dealer or a mobile locksmith hook up to the obd2 are reprogram the transponder.
  5. #5
    JK Enthusiast txjeeplover's Avatar
    Join Date
    Feb 2007
    Location
    Austin, Texas
    Posts
    333
    It's my understanding that as an anti-theft measure, you can't defeat the WCM. If it's removed or replaced the Jeep will start for second and stop until the computer is reprogrammed to recognize the new WCM. In addition, each key will have to be reprogrammed.
    If you think you'll end up replacing the computer, I'd install a new computer and WCM then tow the Jeep to the dealer and have it all programmed at once.
    2008 2dr Rubicon aka "Beau"
    4" Zone lift as a base with Teraflex and other components
    35x13.50R15 Toyo Open Country MT
    15x10 Ion 138
    A bunch of other stuff
  6. #6
    Join Date
    Jul 2008
    Location
    Tyler, TX
    Posts
    2,509
    Quote Originally Posted by txjeeplover View Post
    ah.
    no funds available for either of those parts.
    maybe i can figure out something else.
    ( lllllllllllllll )
    l_MK 1:12_l
  7. #7
    JK Super Freak BlackNorthernJK's Avatar
    Join Date
    Mar 2008
    Location
    Alberta
    Posts
    1,673
    to reprogram a new key I just purchased (because I'm missing my second one) it only cost 35 bucks....but for fun, before I got the chipped keys programmed, after I got them cut I tried starting the Jeep with them, they will start the vehicle, it will then run for a few seconds before dying and flashing that red led on the dash....so if Tonka is still not even starting for a second, I don't think this is the problem
    NORTHRIDGE4X4
  8. #8
    Join Date
    Jul 2008
    Location
    Tyler, TX
    Posts
    2,509
    Quote Originally Posted by BlackNorthernJK View Post
    thats exactly what its doing....starting for 1-3 seconds, then dying.
    Red LED is upper right of fuel guage
    did you tow it to the dealer?
    ( lllllllllllllll )
    l_MK 1:12_l
  9. #9
    JK Freak mattymat04's Avatar
    Join Date
    Mar 2007
    Location
    long island ny
    Posts
    611
    sounds to me like you are on the right track either the trasponder broke or its on the computer end.
    check the (my jk) got to long here
    www.Northridge4x4.com
  10. #10
    Join Date
    Jul 2008
    Location
    Tyler, TX
    Posts
    2,509
    Quote Originally Posted by mattymat04 View Post
    actually, the transponder fell apart, and I may have put it back together wrong.
    Anyone have access to a diagram for it?
    ( lllllllllllllll )
    l_MK 1:12_l
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
