Dash Lights Going Crazy and Wont's Start
I have a 09 Wrangler X. My dash gauge lights start going crazy and the odometer scrolls with hot/ oil etc. Jeep continues to run, but the AC seems to go out. When I tun it off, it will not start. No juice, but the battery is fine. May take 4 to 15 turns before it starts. Other times, it starts right away. Dealership replaced the ignition switch awhile ago, but blame the problem on after markets lights etc.
Had the battery load tested and the battery is excellent as is the alternator.
Any assistance is greatly appreciated, so thanks in advance!
Here is the link to the video of my dash going crazy!
https://youtu.be/NHdmyPwkRiE
Does this mean the engine is cranking, but not actually starting? Or that the starter motor is spinning and the engine is not rotating (starter is not engaged with the flywheel)? Or that the starter doesn't turn, or turns very slowly and the engine doesn't fire up?
No engine crank, starter spin etc. It;s like the battery is completely dead, except the dome light is on. I have a remote starter and that to does not work. I think it may have something to do with the wiring in the ignition switch, but I am not electrician.
Here is the link to the video of my dash going crazy! https://youtu.be/NHdmyPwkRiE
I had the same issue with my 2013 JK 2-door earlier in the year. It would start out fine for about 3 to 5 minutes and the dash would go crazy blinking as your video showed. When I turned off it would not restart for 15 to 20 minutes. Ended up towing to the dealership. They replace the PCM along with 2 wiring harnesses. Thee had it for about 3 weeks. I had originally tried tightening the battery connection and even disconnected to try and reset. Since I got the Jeep back not a single problem. Probably not what you want to hear. Thank God I was covered under warranty.
When you reinstall the battery, ensure that you clean the battery clamps. There are special wire brushes for that purpose--the parts store will sell you one. Once you've put the battery clamps back on and cleaned up and inspected all of the various connections on the clamps, spray just a tad of WD-40 on the battery terminals and clamps. That will keep corrosion from starting up (you don't need those silly felt disks the parts store sells to prevent battery terminal corrosion). I respray those clamps with just a smidgen of WD-40 every time I change oil.
As for the ignition switch: While at the parts store pick up a can of CRC electrical contact cleaner. Use the straw that comes with the can and spray that into the ignition switch, stick your key in, and rotate it around. Do that quickly because the cleaner evaporates almost immediately. Do several times.
