Need Help on Hella lights
Old 11-24-2010, 02:22 PM
Coondog33's Avatar
Default Need Help on Hella lights
i am wiring my hella lights up and i cant get then to work...i searched and read all the threads..wired like i think it should be...any help would be great
Old 11-24-2010, 02:24 PM
09GRNJK's Avatar
What does your setup look like now??
Old 11-24-2010, 02:27 PM
Coondog33's Avatar
i have everything wired like the diagram says....i do not have th wire going from headlight to switch...could it b a bad ground on the front lights
Old 11-24-2010, 02:31 PM
09GRNJK's Avatar
Get a test light and work your way section by section, and make sure the lights are getting power.
I'm not too sure what the schematic looks like, but seems like you may have a connection issue somewhere.
Old 11-24-2010, 02:42 PM
Coondog33's Avatar
ok..would i just wire it to th positive post on battery
Old 11-24-2010, 02:46 PM
Coondog33's Avatar
thank you...i ll give it a shot..i like that idea
Old 11-24-2010, 02:58 PM
crawlah's Avatar
Dont forget a fuse if your going strait to the battery you dont want to burn your jeep to the ground
Old 11-24-2010, 03:05 PM
Coondog33's Avatar
riptide that was it...guess i didnt have connection when i tried to wire to my headlight...the wire going to the battery has a fuse in it...is that what you mean
Old 11-24-2010, 03:11 PM
Coondog33's Avatar
thank you for your help...i was banging my head against the wall...
Old 11-24-2010, 04:06 PM
Coondog33's Avatar
Will do. Wasted alot of time today. Gonna get my windshield lights done tomorrow. Then ill post. Thanks again.
Quick Reply: Need Help on Hella lights
