DIY backup camera mounting with external monitor
Old 12-09-2016, 07:13 PM
javara's Avatar
Default DIY backup camera mounting with external monitor
So the reason why I use external monitor is because in the country where I live,
finding lockpick or any other integration modules is almost impossible.
Anyway, the monitor and reverse camera are really cheap.
Found them in a local online market for $36 (for both)
Name:	00013 Jeep JK Backup Rear View Reverse Camera.png
The location of choice is behind the spare tyre..
Name:	UL00002 Jeep JK Backup Rear View Reverse Camera.jpg
ID:	662517Click image for larger version
Name:	UL00001 Jeep JK Backup Rear View Reverse Camera.jpg
Again, aftermarket products for camera mounts are hard to find,
so I happened to find some machined aluminum piece laying around in my workshop,
which fits the space inside the spare tyre with a little bit of modifications.
Drilled a couple of holes on the spare tyre mounting. It's made of soft alloy which is very easy to drill.
Then the aluminum piece is bolted into the holes
Name:	UL00008 Jeep JK Bac  kup Rear View Reverse Camera.jpg
Run the wires through the existing wire lines and into the back of the sub,
connect them with the reverse light cables..
And through the bullbar sleeves all the way to the overhead sunshade panel..
Name:	UL00010 Jeep JK Backup Rear View Reverse Camera.jpg
I used some gopro arms and mounting as the monitor happens to have the gopro-compatible mounting..
It gives the advantage of adjustability..
Name:	UL00006 Jeep JK Backup Rear View Reverse Camera.jpg
Tada! Now I can safely reverse the car with minimal risk of running into my daughter's coupe.. Lol..
*My jeep is RHD
Name:	00003 Jeep JK Backup Rear View Reverse Camera.jpg
ID:	662533Click image for larger version
Name:	UL00012 Jeep JK Backup Rear View Reverse Camera.jpg
Quick Reply: DIY backup camera mounting with external monitor
