Dual tone horn wiring
2012 Wrangler Sahara.
I have a set of PIAA horns coming to replace my wimpy stock horn. The question I have is about the wiring. Some say paralell.....some say in series. Now I am not sure and I really don't want to burn out a relay or cause some problem with the remote start or alarm system. Some say include a relay. Some say the stock setup will handle the two horns. If so.....which way to wire them so I don't blow the stock wiring....Anyone done this for real? Feedback needed please. Include a link to a write up with pics maybe???
Thanks!
Thanks!
Thanks!
Thanks!
If the stock system will support one of the horns you have, the other horn can be connected to the other unused horn fuse.
There is no wire under the fuse, so a fuse tap would be needed.
I mounted a big snail horn from an F350. Traded my take off springs and shocks for it and a few other parts at the salvage yard. Used the original horn wiring to set off a relay then powered both the F350 horn and my original horn from a separate power feed. I tried piaa but they were just not right for a jeep. The big truck horn plus the stock horn has a great sound and is seriously loud. I had to suspend the horns from a mount I made that I riveted to the hood frame.
When it comes to wiring I am an amateur at best. If someone could help with a simple diagram (nix the fancy electronic symbols) I would greatly appreciate it. I agree this should be a simple install. However I just don't have the wiring skills to be confident enough with just a verbal description. Also if I am to use a relay....What type and spec? I understand what a relay is. I don't understand which wire to connect to what terminal on the relay. Having said that it seems the spare fuse idea would be a bit simpler. Yet again. I do not understand what the wiring should be. Please forgive my ignorance.
1) Go to your local automotive shop and purchase a complete aftermarket lighting harness.
2) Install the harness in the engine bay and connect the lighting leads to your new horns.
3) Cut the switch away from the new lighting harness.
4) Connect the OE horn wires to the wires that was attached to the aftermarket switch.
Thanks for all the responses. However I need to know specifically about the connections. Most people are telling me to go with connections in parallel. That I do understand. Still.....I do not want to ruin anything. I guess the worst that could happen is I blow a fuse.....????
You have been given information to do the install correctly. Either option only takes a little bit of work. Why take the chance for a horn?
My 2011 Sahara came with 2 horns. However wasn't dual tone anyway or it was and only one of them was working.
One of the horns was right behind the front bumper, the other one behind the left headlight.
I removed the one from the bumper when I installed the AEV bumper.
