Front Door wiring harness connector
I just installed my old front half doors from my 2012 JK to my 2015 JK. The harness connector has changed. I had an adapter on my old half door harness to mate with the 2012 (rectangle with rounded corners) but the 2015 (rectangle with square corners) has a different connector. Does anyone know of a new adapter that will mate with the 2015? or even a part number for a new connector on the door side that mates with the jeep harness.
I just connected some 2012 half doors with power locks to my 2013 jeep that has the gray connector. While also researching connectors, I found where someone just removed the upper black casing and the plug will then fit in the newer gray connector. I was skeptical, but it actually works. I ended up switching two wires in the older harness from the door to make the door locks work properly. If you just want the interior lights to wirk, then you'll be fine.
Looks like these guys have them. Just enter year and model and scroll down to inline-door...
Mopar Connection Repair Kit
