fuse blowing
fuse blowing
Hi everyone. I need some help. I have a 09 jk unlimited 4 DR and took a road trip to Florida with the family from Chicago. When I arrived somebody info me that my brake light was out. So no problem. Went out and put a new one. But it still didn't work. Went to check the fuses under the hood and found a blown fuses for the brake/parking lights. Replaced that and blew it instantly. Also replace all the bulbs on the drivers side. What am I missing?
Is it all the brake lights or just the spare tire light? My spare kept blowing the fuse for all the brake light bc the wire that goes through the back door and into the electrical plug was frayed from slight contact with the metal.it would be a good place to start.
What is the fuse number that keeps blowing out?
Well, my problem has now gotten worse. So, i put new bulbs in front turn signal, rear brake, and front fender. And installed a new fuse. Drove home perfect last night. Got in this morning and absolutely nothing when i turn the key! WTF happened? Thought it was the starter and put one in. Nope. That wasn't it. Then I checked the the bulbs I put in and found the front marker bulb has shorted to a point of melting the connecter it was in. Help!! I don't know what Happened. Just doesn't do anything when I turn the key.
