Fuse Box Layout Map - JK 2009 2-door
Old 01-29-2010, 06:23 AM
Robert K's Avatar
Default Fuse Box Layout Map - JK 2009 2-door
Since the fuse layout map on the inside cover of the fuse box is tough to read for those of us with older eyes, and since there have been several threads requesting such a diagram, I thought I'd go ahead and post this for whoever finds it useful.
If anyone sees any mistakes, let me know immediately and I'll fix it. Note that this is from my 2-door JK 2009... I don't know if there are any differences between the 2-door and the 4-door, nor if there were any changes between 2007 or 2008.
Cavity
Cartridge Fuse
Mini Fuse
Description
J1
40 Amp Green
Power Folding Seat
J2
30 Amp Pink
Transfer Case/Pwr Liftgate Module
J3
40 Amp Green
Rear Door Module (RR DOOR NODE)
J4
25 Amp Natural
Driver Door Node
J5
25 Amp Natural
Passenger Door Node
J6
40 Amp Green
Anti-Lock Brake System (ABS) Pump/ESP
J7
30 Amp Pink
Anti-Lock Brake System (ABS) Valve/ESP
J8
40 Amp Green
Power Memory Seat (If Equipped)
J9
40 Amp Green
PZEV Motor/Flex Fuel
J10
30 Amp Pink
Headlamp Wash Relay/Manual Tuning Valve
J11
30 Amp Pink
Sway Bar/THATCHAM Lock-Unlock/Power Sliding Door Module
J13
60 Amp Yellow
Ignition Off Draw (IOD) — Main
J14
40 Amp Green
EBL (Rear Window Defogger)
J15
30 Amp Pink
Rear Blower
J17
40 Amp Green
Starter Solenoid
J18
20 Amp Yellow
Powertrain Control Module (PCM) Trans Range
J19
60 Amp Yellow
Radiator Fan
J20
30 Amp Pink
Front Wiper LO/HI
J21
20 Amp Yellow
Front/Rear Washer
J22
25 Amp Natural
Sunroof Module
M1
15 Amp Blue
Center High Mounted Stop Light (CHMSL)/Brake Switch
M2
20 Amp Yellow
Trailer Lighting
M3
20 Amp Yellow
Frt/Rear Axle Lockers
M4
10 Amp Red
Trailer Tow
M5
25 Amp Natural
Inverter
M6
20 Amp Yellow
Power Outlet #1/Rain Sensor
M7
20 Amp Yellow
Power Outlet #2 (BATT/ACC SELECT)
M8
20 Amp Yellow
Front Heated Seat
M9
20 Amp Yellow
Rear Heated Seat (If Equipped)
M10
20 Amp Yellow
Ignition Off Draw — Vehicle Entertainment System (IOD-VES), Satellite Digital Audio Receiver (SDARS), DVD, Hands Free Module (HFM), RADIO, Antenna (ANT), Universal Garage Door Opener (UGDO), Vanity Lamp (VANITY LP)
M11
10 Amp Red
(Ignition Off Draw) IOD-HVAC/ATC, MW SENSR, Underhood Lamp (UH LMP)
M12
30 Amp Green
Amplifier (AMP)
M13
20 Amp Yellow
Ignition Off Draw— Cabin Compartment Node (IOD-CCN), Wireless Control Module (WCM), SIREN, Clock Module (CLK MOD), Multi-Function Control Switch (MULTIFCTN SW)
M14
20 Amp Yellow
Trailer Tow (Export Only)
M15
20 Amp Yellow
COL MOD, IR SNS, Heater Ventilation, Air Conditioning/Automatic Temperature Control (HVAC/ATC), Rear View Mirror (RR VW MIR), Cabin Compartment Node (CCN), Transfer Case Switch (T-CASE SW), RUN/ST, Multi-Function Control Switch (MULTIFTCN SW), Tire Pressure Monitor (TPM), Glow Plug Module (GLW PLG MOD) — Export Diesel Only
M16
10 Amp Red
Occupant Restraint Controller/Occupant Classification Module (ORC/OCM)
M17
15 Amp Blue
Left Tail/License/Park Lamp (LT-TAIL/LIC/PRK LMP)
M18
15 Amp Blue
Right Tail/Park/Run Lamp (RT-TAIL/PRK/RUN LMP)
M19
25 Amp Natural
Auto Shut Down (ASD #1 and #2)
M20
15 Amp Blue
Cabin Compartment Node Interior Light (CCN INT LIGHT), Switch Bank (SW BANK), Steering Control Module (SCM)
M21
20 Amp Yellow
Auto Shut Down (ASD #3)
M22
10 Amp Red
Right Horn (RT HORN (HI/LOW)
M23
10 Amp Red
Left Horn (LT HORN (HI/LOW)
M24
25 Amp Natural
Rear Wiper (REAR WIPER)
M25
20 Amp Yellow
Fuel Pump (FUEL PUMP), Diesel Lift Pump (DSL LIFT PUMP) — Export Only
M26
10 Amp Red
Power Mirror Switch (PWR MIRR SW), Driver Window Switch (DRVR WIND SW)
M27
10 Amp Red
Ignition Switch (IGN SW), Window Module (WIN MOD)
M28
10 Amp Red
Next Generation Controller (NGC), Transmission Feed (TRANS FEED), J1962
M29
10 Amp Red
Occupant Classification Module (OCM)
M30
15 Amp Blue
Rear Wiper Module (RR WIPER MOD), Power Folding Mirror (PWR FOLD MIR)
M31
20 Amp Yellow
Back-Up Lamps (B/U LAMPS)
M32
10 Amp Red
Occupant Restraint Controller (ORC), TT EUROPE
M33
10 Amp Red
Next Generation Controller (NGC), Global Powertrain Engine Controller (GPEC)
M34
10 Amp Red
Park Assist (PRK ASST), Heater Ventilation, Air Conditioning Module (HVAC MOD), Headlamp Wash (HDLP WASH), Compass (COMPAS)
M35
10 Amp Red
Heated Mirrors
M36
20 Amp Yellow
Power Outlet #3 (BATT)
M37
10 Amp Red
Anti-Lock Brake System (ABS) , Electronic Stability Program (ESP), Stop Lamp Switch (STP LP SW), Fuel Pump Rly Hi Control
M38
25 Amp Natural
Lock/Unlock Motors (LOCK/UNLOCK MTRS)
Old 01-29-2010, 06:28 AM
Robert K's Avatar
One question I have about the above:
The driver's side power outlet #1 is M6.
The passenger side power outlet #2 is M7.
The legend shows M36 as Power Outlet #3... where exactly in the Jeep is this power outlet?
Also, it mentions a "rain sensor" on M6 as well... what's this all about?
Old 01-29-2010, 06:41 AM
Mike Davis's Avatar
Nice job. Thanks. Did the JK ever have heated seats? I used M8 for my aux hook up. Mike
Old 01-29-2010, 06:47 AM
Robert K's Avatar
Thanks. Mine never had heated seats... no power windows, no power mirrors, no power door locks.
Old 01-29-2010, 06:51 AM
Mike Davis's Avatar
I think they probably use that fuse box in many Jeep and/or Chrysler vehicles and just connect the options as the vehicle model dictates.
Old 01-29-2010, 07:00 AM
Ralioth's Avatar
Thanks for the help. This makes it a lot easier to read. It's a sad day when you realize the world is writing everything smaller. Instruction manuals, pill bottles, the font on your monitor...
Signed:
Junior Geez
Old 01-29-2010, 08:45 AM
HotFrosty's Avatar
So if there is a place for a fuse and it's not a option you have, are the wires still run for that option?
Example: I don't' have power seats but buy them from a junk yard. Can I just plug them in to a existing wire and plug in a fuse, and now have working power seats?
Thanks Robert For all your work on making this list!
Old 01-29-2010, 09:55 AM
Robert K's Avatar
That's a good question, because I've seen MOPAR instructions for the OEM heated seat components that have you wiring them into the power outlet on the driver's side... (i.e., nothing to do with M8 or M9)... which makes me think that sometimes the circuitry is not there if the vehicle didn't have the option coming out of the factory.
http://www.quadratec.com/Assets/Installation/100094.pdf
And yet, there are several write-ups on this board that have people using M8 and M9 as supply power sources for other projects (e.g., auxiliary lighting), so those slots in the fuse box are indeed "live" and ready for use.
Other things, like the OEM fog lights I installed after I bought the Jeep, did have all the internal circuitry wiring already installed, once you hooked the actual light wires up to the harness underneath the fuse box and changed the switch at the steering column... but in order for the lights to actually work, the dealer had to "flash the computer".
http://www.mopar-accessories.com/en-....ashx?id=15094
Old 02-07-2010, 01:41 PM
John_B's Avatar
Robert K,
Thanks for the detailed mapping
Old 07-03-2010, 10:19 AM
Waiting's Avatar
Default I hadn't noticed the fuse puller...
...the first few times I went in there, so I mention it is under J11 in the diagram above. Hopefully, I'm the only bonehead who had trouble finding it.
Quick Reply: Fuse Box Layout Map - JK 2009 2-door
