Genesis Offroad JK dual battery install
Awesome upgrade and write up, I also had not considered a dual battery set up till I saw this as I didn't want to hack and cut my battery tray and such.
Just a suggestion to anyone do ing this mod. While that battery tray is out it is a perfect time to replace your spark plugs if needed. Makes it so easy to get the passenger side plugs. I removed my battery tray to do mine instead of fiddling through the wheel well or working blindly.
[/QUOTE]
Great write up! Sigh... Now if all instructions came that way.
It looks like you are have your wires on the accessory battery (front) routed through the wrong hole and/or are missing the rubber grommet on the positive cable. It looks like you may have an extra grommet on the cranking battery that is not in use.
I would be concerned that the positive cable would rub through and arc.
I would be concerned that the positive cable would rub through and arc.[/QUOTE]
It does have a grommet around it that wasn't installed in the picture. I had taken it out to see if it would fit in the bracket im making for my ARB compressor.
Dr. Dirty that was an awesome write-up! I thank you. I have been adding some accessories to my rig and was wondering what some other members were doing or how they were connecting the wires.
