Help: Not all of the interior lighting works (dome, window switches, consule).
#21
Since the door lock switches and dome light both relate to the doors, I would check all the door electrical connections to make sure nothing is unplugged or not seated. Maybe even when they were working on the amp they unhooked a door strap to open it more and stretched out the door wires. The gear indicator lights may be tied to the same feed. Just a thought and easy to check.
When the door is closed, it creates an open circuit, and when the door is open, it closes the circuit to send a signal to the TIPM and the TIPM in turn sends out a message over the CAN bus and that's how the instrument cluster finds out a door is ajar. The door switches are all wired in a series, so regardless which door you open, the TIPM only gets one signal. So by disconnecting all doors at the connector, you are creating an open circuit and as far as TIPM can tell, it thinks all the door are installed and closed. This is why on newer JK's you don't get a door ajar light when you take off all the doors. The instrument cluster gets another signal from somewhere in the driver
side door switch to let it know the Driver door is open and its only purpose to illuminate the odometer when the ignition is OFF, the service manual calls this "Rental Car Mode" for some reason.
#22
It blows to own a car that's covered under warranty and actually need work to be done, but have no where to take it. Jeep dealers here in Korea, WILL NOT provide warranty service to Jeeps not sold in Korea as Export Jeeps. Even though I bought my Jeep here, its a US Spec Jeep sold on the US market. So I am supposed to use some little trashy shop mandated by Exchange New Car Sales (aka Military Car Sales). That's the equivalent of taking this problem to the high school kids at Jiffy Lube and letting them try to fix it. Even IF they could find the problem, if it required a replacement part, it takes months to get the part here. It took 2 months just to get a replacement amplifier.
#23
6. I then decided what the hell, lets see what happens when I do this... and I jumped a hot 12v wire onto the OR/GY wire coming out the back of the Power window switches and to my amazement.... I have light! Every light that didn't light up before was lit (window switches, shifter indication, drivers side power door lock button).
#24
What I would do next is trace the OR/GY wire from the window switches back to it's prior connector and check for voltage there. If no voltage I would trace back from there to its previous connector and so on. Once you find voltage then run a continuity test from that connector back forward to the last connector you checked. A stretched wire can break internally while leaving the insulation intact. Without a schematic, that is the only way I can think of to find it. Sounds like you really know what you're doing so good luck...you'll find it I'm sure.
But, I think there is a more prevalent issue to address... why is there 4.6 volts sitting on my courtesy light wire, when it should be in an open (0v) status?
#25
That is a good question. I have read when checking for a short you have to wait at least 10 minutes before checking because the Jeep does continue to use power after shutdown for about that amount of time. Did you check the voltage at the dome after the door had been closed for at least 10 minutes?
#26
I took my dome light to work with me today and put it on a bench tester at 10v to figure out its circuit paths. I see now that it was wired correctly however the wire color locations do not match up with the diagrams.
Unfortunately I'm not going to get another chance to dig in more until this weekend.
#27
Had a couple minutes before I went to work today, so grabbed the multimeter again and played some more.
The YL/BL wire out the back of the cluster is a mystery to me... When the ignition is off, I get 4.6v and if you use the dome switch on the dimmer, it will go to 12v. If you open the door it will go to 12v. Close the door and 30 seconds later is will go back down to 4.6v. Turn the ignition to ACC or ON and it instantly goes to 12-14v. All the while, the YL/WT wire is dead under all conditions.
I think I am going to try ordering a new instrument cluster and see what happens, since the cluster is the brain of the whole system. EDIT: Was going to shotgun a part, but instrument clusters are $370~
#28
Starting to believe 2011 is just a screwball year. I have now come across multiple posts by different 2011 owners over several different thread concerning wiring related to dome lights. Mostly threads about wiring in LED footwell lighting to the dome switch. Several 2011 owners stated that they could not get power off the YL/WT wire going to the Dome light.
#30
I would like to know as well. I have the two door 2011 black ops and have the same problem. Dash lights work with dimmer but the dome, window, and gear shift are out and no power to the orange/grey wire?
