Anyone know what these holes are for on rear console?
Old 01-04-2013, 03:45 PM
bobholthaus's Avatar
Default Anyone know what these holes are for on rear console?
Almost looks like a spot for a microphone. Any ideas? They are on both sides. Thanks.
Old 01-04-2013, 04:07 PM
carolinajk's Avatar
Attachment 405579
used condom disposal?
Old 01-04-2013, 04:21 PM
JK-Ford's Avatar
Rear seat A/C vents?
Old 01-04-2013, 04:31 PM
notsoricer's Avatar
Vent any heat possibly collecting in there from tranny?
Old 01-04-2013, 04:32 PM
The funny thing is that they are perforated all the way through. If this was an Audi or Mercedes, I would think it was a sensor location for rear seat HVAC control. Sadly in our JKs, they didn't even route any warm air ducts under the front seats to help put some heat back there!
Old 01-04-2013, 04:33 PM
When I take my console apart to run some 12v sockets, I will let you know what I find, ha!!
Old 01-11-2013, 06:52 PM
AtlJeepsTer's Avatar
Attachment 405579
The window switches are Lit (in some models) when the Headlights are on and the heat builds up.
Old 01-02-2014, 12:04 AM
They do nothing. I finally took the console apart tonight to put rear seat heater switches in. Btw, those lights in the rear window switches are LED so they do not get hot! Here's a pic of the back of them. I guess they could vent heat build up under the console, but I don't think there's anything under there that gets hot! Click image for larger version
ID:	520624 Btw, just pull the plastic trim piece up (that is right above these on the inside of the console, in front of the hinge thing) and you can see the back of these. Here is where I put my rear seat heater switches: Click image for larger version
Old 01-02-2014, 01:56 AM
Navyvetnorwich91's Avatar
....that's what she said...
Old 01-02-2014, 04:14 AM
Jeepstin12's Avatar
They do nothing. I finally took the console apart tonight to put rear seat heater switches in. Btw, those lights in the read window switches are LED so they do not get hot! Here's a pic of the back if them. I guess they could vent heat bud up under the console, but I don't think there's anything under there that gets hot! <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=520624"/> Btw, just pull the plastic trim piece up (that is right above these on the inside of the console) and you can see the back of these. Here is where I put my read seat heater switches: <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=520626"/>
OK, OK. Now you need to do a write up on the rear heated seats you are working on.
Quick Reply: Anyone know what these holes are for on rear console?
