How did you fill you SPOD!
Please share how you filled up your SPOD! 6 switches of fun.. I have my 50" on one and pillar lights on another.. I don't really do any serious off-roading so no need for air. Rock lights? How about FU lights?? Please share..
I am in the process of building a 8 switch panel that goes in the same spot as the spod. It will be
1 Led Pods
2 Back up lights
3 Rock lights (when I install them)
4 CB
5 Winch power
6 Winch in/out
7 USB ports
8 TBD
Not really necessary but I had room for 8 switches
1 Led Pods
2 Back up lights
4 CB
5 Winch power
6 Winch in/out
7 USB ports
8 TBD
1 = Hella's on brush guard.
2 = 40" Light bar above front window
3 = Small LED Winch lights
4 = not used yet (more likely KCs Hilites will be mounted on bumper)
5 = not used yet (more likely all around vehicle camping lights mounted on roof rack)
6 = not used yet (more likely rock/under vehicle lights)
I do off-road, and use all of the switch functions. The two roof light switches control the left and right bank of lights because the sPOD can't carry the capacity on just one circuit. I plan to modify that so all four are on one circuit, then wire up a rear area light. The switches and oil pressure gauge are wired into the dash variable lighting control. If I ever find an analog oil pressure/battery voltage gauge, I plan to replace the gauge (would like battery gauge for aux battery in dual-battery set-up). I've also rewired the sPOD so that the button on the left, which was originally for turning on the switch backlighting, is now an sPOD functions disable button. When depressed, all switch functions are disable/enabled. Prevents the ignorant passenger from causing damage as he reaches up while I'm tooling down the Interstate and asks, "What's a front locker?" as he pushes the front locker switch. The engine fan switch, BTW, does not turn the fan on and off. Rather it turns the fan off, or places the fan under control of the Jeep. Fine, but important, distinction.
I do off-road, and use all of the switch functions. The two roof light switches control the left and right bank of lights because the sPOD can't carry the capacity on just one circuit. I plan to modify that so all four are on one circuit, then wire up a rear area light. The switches and oil pressure gauge are wired into the dash variable lighting control. If I ever find an analog oil pressure/battery voltage gauge, I plan to replace the gauge (would like battery gauge for aux battery in dual-battery set-up). I've also rewired the sPOD so that the button on the left, which was originally for turning on the switch backlighting, is now an sPOD functions disable button. When depressed, all switch functions are disable/enabled. Prevents the ignorant passenger from causing damage as he reaches up while I'm tooling down the Interstate and asks, "What's a front locker?" as he pushes the front locker switch. The engine fan switch, BTW, does not turn the fan on and off. Rather it turns the fan off, or places the fan under control of the Jeep. Fine, but important, distinction. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=615476"/>
1. ARB air compressor
2. Front locker
3. Rear locker
4. Bumper lights
5. A pillar lights
6. Rock lights
Wish list to upgrade to the eight switch
7. Line lock left rear
8. Line lock right rear
2. Front locker
3. Rear locker
4. Bumper lights
5. A pillar lights
6. Rock lights
1). ARB Twin compressor
2). CB
3). Winch Power (used warn power interrupt kit)
4). 50 Inch LED Bar
5). N/A
6). N/A
Just means I need to spend more money
2). CB
4). 50 Inch LED Bar
5). N/A
6). N/A
1) A-Pillar D2s
2) 50" SR2 Light Bar
3) Rear Duallys
4) A-Series Rock Lights
5) Zombie Lights (Strobe flasher for all lights)
6) ARB compressor
May be upgrading soon...that new sPod SE looks like a good expansion.
3) Rear Duallys
6) ARB compressor
