I found this wire harness hidden in the back of my JKU Sport S
Originally Posted by suds1485
if its a 2 pin connector check for voltage at key on. if it has 12 volts use it as an aux port
Subscribed. I was looking for a source for an outlet, but this seems to have too many wires. Optional speaker harness would be my guess. This is where it would be good to have an owner repair manual. They usually have wiring diagrams in them. Might have to go look for one on ebay.
This is the plug for the factory subwoofer and 12V outlet. I just found mine while I was installing an Orfab tire carrier. It was plugged into the harness that runs to the plastic housing for the subwoofer. You should be able to put a test light on it and find the pair that is powered.
Steve
Steve
Steve
Steve
I want a rear outlet. I planned to power it direct from the battery or a fuse tap. I don't have a sub woofer housing so I'm looking for places to install the 12 volt outlet. I remove the right rear panel and I find this.
Attachment 299024
Attachment 299025
Is this the harness for what would be a sub woofer and rear power outlet? And if it is, does anyone know if/how I can tap into it? Being relatively new here, do any of you know anyone more versed on this forum that I can run this question by?
Attachment 299024
Attachment 299025
