video for DIY "Dbox" like an SPOD
Old 12-02-2012, 12:38 PM
4W-Jive's Avatar
Default video for DIY "Dbox" like an SPOD
Here are the videos, is this terrific? anyone notice anything dangerous about them?
Off-Road Lighting - How the DBox is made. (Part: 1) - YouTube
Off-Road Lighting - How the DBox is made (Part: 2) - YouTube
It looks great to me, I just want a pro to look it over before I start.
Old 12-02-2012, 01:14 PM
4W-Jive's Avatar
Maybe I should include this too, its the Dbox in use and mounted up to a JK
https://www.youtube.com/watch?v=N_ROak8PQ4E
Old 12-02-2012, 03:07 PM
JK-Ford's Avatar
Looks OK. There is plenty room for improvement. The only thing that I dislike the most is: the builder has restricted the load carrying capacity to only 30 amp. This is only enough power to feed just ( 1 ) of my lighting circuits.
Old 12-02-2012, 03:09 PM
4W-Jive's Avatar
would improvement be as simple as a thicker gauge power wire and a higher amperage in line fuse? Or is it at 30 amps for some other reason?
Old 12-02-2012, 04:11 PM
JK-Ford's Avatar
The main power wire and inline fuse holder in the vid was #10 awg/30 amp. This wire and fuse should be bigger. Full load capacity of ( 5 ) 30 amp relays would be 150 amps. But, if you design this circuit around a known load ( if you already know everything that you want to connect ), then you may not need this much capability. Also, the builder went to a lot of trouble to get a water-prof inclosure. But he didn't make water-prof penetrations in the box. If he were to use multi conductor corded cable with weather prof CG connectors. Then he would have a water tight installation.
Old 12-02-2012, 05:23 PM
holeshot's Avatar
I did something simillar in my friend's jk.
Name:	2012-10-19 12.04.03.jpg
Old 12-02-2012, 09:31 PM
Mjkrakow's Avatar
that is exactly what i posted on his video.
I am using a 85 am circuit breaker with a 4 gauge wire in my auxiliary fuse box.
work in progress:
Old 12-03-2012, 10:23 PM
overkilljk's Avatar
This is the guy in time say "His jeep catch on fires in the mid of the night, and dose not know why"
Old 12-04-2012, 05:41 AM
JK-Ford's Avatar
If he steps up his fuse because it keeps blowing, then you are correct.
Old 12-04-2012, 06:20 AM
Blade's Avatar
This is why I use SPod. It is tried and proven and definatly the cleanest looking power management system on the market. Now if only it didn't cost an arm and a leg.
Quick Reply: video for DIY "Dbox" like an SPOD
