Ipad Mini Install
Old 02-14-2014, 06:28 AM
  #131
01svtL's Avatar
So what all would I need if I wanted to buy a cheap single din aftermarket radio (but something that sounds better than the stock head unit) to run off of, and then control it all with the ipad mini, keeping XM, AM/FM, CD, and steering wheel functions?
Does the ipad just function as a source like a tv, and outputs the sound through the radio (like an a/v amp) and from the radio out to the speakers?
If this is the case, and I wanted to get a cheaper single din for better sound, how do I keep my XM funcionality?
Old 02-14-2014, 01:19 PM
  #132
olsen185's Avatar
Originally Posted by TacomanBJK12
Resurrecting this thread from the dead... Any update on and iPad Mini mount for an 08? thanks.
No I have just about given up on that. I haven't had any luck with that.
Old 02-14-2014, 01:27 PM
  #133
olsen185's Avatar
If you want to add an aftermarket radio make sure it has a USB input. You will need a wire harness, an antenna adapter and another adapter to retain steering wheel controls (very important!).
With that setup you can control the volume and source from the steering wheel. There are also ipad apps for XM radio. While am/fm radio will be functional, and the source and stations can be controlled with the steering wheel controls, you won't want to listen to it any more after having crystal clear internet or sat radio. There are some fm radio apps available, but they don't have every station.
Old 04-14-2015, 11:27 AM
  #134
Wordzero's Avatar
I've searched and haven't been able to find what I'm looking for but is there anyone that makes a dash mount for the 2007-2010 models? Not something to just mount the ipad but something to take the place of the head unit kinda like the one that angryoffroad makes.
Old 04-20-2016, 09:28 AM
  #135
A-Ham's Avatar
Hi, Im new. I've been reading on this thread for a bit, and ive been looking for a solution to using my ipad as a head unit for my 2010 wrangler.. Any solutions?
Old 04-20-2016, 04:07 PM
  #136
mds22's Avatar
you realize this thread is 2-3 years old. Better off starting a new one.
Old 04-27-2016, 05:07 PM
  #137
TakeABackRoad's Avatar
I run a vector mount with a ram holder
Also angry Offroad makes a holder but personally I liked the vector option better
Old 04-27-2016, 05:09 PM
  #138
Old 04-27-2016, 05:10 PM
  #139
This is the angry Offroad version
Quick Reply: Ipad Mini Install
