Jeep wont turn off!!! Please help!!!
#21
But normally on the JK...
Voltage is monitored at the B+ terminal stud to insure it is connected. If the B+ cable is loose, the PCM will shut down generator field.
It has been shown in past threads the JK engine will not continue to run when the battery is disconnected.
#22
No it's a common thing if the tipm issue. Mine has done the same thing a couple of times. Jeep freaked the hell out and turned off removed key and everything kept running and freaking out. Put key back in and turned it over like I was starting it and everything went back to normal finally.
#23
Now that I think of it, once in awhile it will do 2 things ... 1) throw a long start, maybe 5-10 seconds, ultimately starting. Or 2) make a click like the battery is dead or starter is shot, then on the 2nd try will turn right over (battery was replaced a year ago)
#25
If the OP's JK kept running even after disconnecting the battery, then yes, his alternator was supplying power to run everything. But normally on the JK... Voltage is monitored at the B+ terminal stud to insure it is connected. If the B+ cable is loose, the PCM will shut down generator field. It has been shown in past threads the JK engine will not continue to run when the battery is disconnected.
#26
