JK fast idle switch FULL install pix to follow,
Yall went to a lot of trouble cuttin and hackin up a perfectly good dash. Looks to me like that high idle light wouldda fit right in the factory switch panel at the bottom of the dash in front of the shifter. It's a nice option though for those with a winch.
HOLY COW $284.95 is what I found online at 4X4RockShop....
Way too much for for something that simple....I can think of many other things for $300 bucks that would be more beneficial for my JK...
The AEV ProCal is $135 http://www.northridge4x4.com/proddet...rod=AEV-Procal
and will allow you to program a timed high idle. along with all these other features as well..
Benefits include speedometer and gear ratio correction to compensate for tire and gear changes, Tire Pressure Monitor System control for running lower than stock pressures, daytime running lamp activation, the ability to temporarily increase the engine idle speed options for improved winching or onboard air compressor performance, and a few other neat tricks that will help installers dial in the vehicle perfectly.
And the best thing is you don't have to drill a single hole or run a single wire..
I called the phone number to find the price. Very easy.
I found 300 delivered to Canada more than fair.
It does what I want, which is the important thing.
